Old 08-19-2011, 04:39 PM
hvacmatt's Avatar
Member #16348
Question having pred issues starting after jetting!!!
i have recently jetted my pred and the bike runs just fine and no back firing but when the bikes cold it ver hard to start till its warmed up its starts right up....
thanks guys
2010 polaris sportsman 550 mossy oak
-3500lbs winch-
2008 polaris outlaw 525S
-uni filter
-swingarm skid plate
-nerfs
2006 polaris predator 500:SOLD:
-nerfs-
-full body skid plates-
-jetted-
-pure polaris pipe-
-UNI airfilter with prefilter
-blueice coolent-
2005 polaris trailboss 330
Old 08-20-2011, 12:37 AM
Old 08-20-2011, 07:07 PM
starpuss's Avatar
Member #16228
Maybe try it w/o the choke.
Old 08-21-2011, 12:57 AM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
whats your main jet size?what is your needle clip position? what elevation are you running at?what temp are you running at? i need more info.
Old 08-23-2011, 12:06 AM
hvacmatt's Avatar
Member #16348
I'm running a 175 main jet, the needle I have ont the 2nd grove from the topwith stock washers and spacers my elev. Is a little bit under a 1000. And temps around here are about 80_90 degrees thanks,matt also its a dyno jet kit
-3500lbs winch-
-uni filter
-nerfs
-nerfs-
-jetted-
-pure polaris pipe-
-blueice coolent-
Old 09-04-2011, 07:51 AM
joshr08's Avatar
Member #13071
what mods did you do to make you change jetting? What jets were in the carb that you took out? i run stock type jets and i know there all different sizes and that makes it hard to help when people run jet kits. But with my 558 kit PP pipe and the baffles and end cap removed a 175 stock type jet is way to big. I think the dynojet jets are bigger in size. Pull your spark plug and look at it. not at the end but up in under the threads. Also you may want to check vavle clearances.
06 polaris outlaw stock setting for jet needle
2006 polaris predator 500 nedle clip position
2006 polaris predator jetting
atv hard to start after installing jet kit
best jetting 06 polaris predator 500
jet kit for 2006 polaris predator 500
polaris predator 175 dyna jet
polaris predator 50 needle clip position
polaris predator 500 choke hard to pull
polaris predator 90 needle position
polaris predator 90 stock needle position
polaris predator runs good hard to start
predator 500 choke issues
predator 500 stock jetting
replacing jet needle on 2003 polaris predator 500
running issues 2006 polaris 330 trail boss
what is stock predator 500 jetting
what is the stock jet on a polaris predator 500
04 pred 500 timing issues mainegreen420 Polaris Predator 1 05-22-2011 05:16 AM
Starting issues with Sportsman 500 BertieNZ ATV Repair and Maintenance 7 01-04-2011 05:40 PM
starting issues phbush2003 ATV Repair and Maintenance 4 01-03-2011 12:58 PM
Magnum 425 Starting issues. blazer74 ATV Repair and Maintenance 3 06-10-2010 06:17 PM
Jetting Issues... jrhammo169 Polaris Predator 0 11-17-2009 06:44 PM
