08-21-2011, 01:28 AM
Member #17889
predator problem need help
First question i have is how much oil do i put in my 05 predator after i change the oil? The guy at my local polaris dealership told me 2 quarts but it is way over on the dip stick. I was riding and it made a high pitched squeel noise and stalled out i got it started again and on the way home it stalled again but this time when i tried starting it it made a grinding noise and then the piston wouldnt move at all when i tried starting after. about an hour later i tried again and it grinded again and the piston seemed free again because it turned over fine idk what to do or where to even start i would greatly appreciate your help thank you very much!
08-21-2011, 05:47 AM
08-22-2011, 05:40 AM
Member #17829
In my 04 pred i do use about 2 quarts after the filter change. Make sure to pull both plugs. I bought 3 quarts of amsoil ow-40 just to be safe. Dont just add the 2 qts right away! You have to check and add. A i would definetly not start that pred again untill i knew what was wrong. Sounds like something internal.
08-27-2011, 08:00 AM
Member #12642
Did you happen to prime to oiling system after the oil change?
09-04-2011, 07:14 AM
Member #13071
you only have to prime the oil pump if the lines are removed from the motor.
09-04-2011, 01:13 PM
Member #15075
I have a question... how often to change the oil? I have a 05 btw
09-04-2011, 05:51 PM
Member #13071
i think it is recommended every 10 hrs in my race quad i do it every other race.
09-04-2011, 09:15 PM
Member #15075
This is my first predator so im sure ill have more questions lol
thanks
how much oil do i put in a predator 500, how much oil do you put in a polaris predator, how much oil do you put in a polaris predator 500, how much oil should my polaris predator 500 take, how to change the oil on a polaris predator 500, how to prime a predator oil pump, polaris 90 predator starter, polaris predator 500 hitch, polaris predator 500 oil change, polaris predator 500 problems, polaris predator 90 oil change, polaris predator 90 problems, polaris predator 90 starter problem, polaris predator fluid capacity, polaris predator oil change, polaris predator problems, polaris predator recommended oil, predator 500 how much oil, predator 500 oil prime, priming polaris predator 500
