Old 08-21-2011, 06:07 AM
Ta2edphreak's Avatar
Member #13890
Exclamation throttle stuck?
i was riding in a firld last night everything was fine, turned it off waited about 5 mins then started it back up and it is stuck at about 50% open throttle, i took the top off the throttle housing and the cable moves fine and dosent seem to be bound up anywhere, any thoughts?
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
Old 08-21-2011, 06:11 AM
jandj's Avatar
Member #12027
I'd start by lubing the cable and looking for a kink somewhere down below.
Old 08-22-2011, 05:44 AM
jonnyb500's Avatar
Member #17829
If that isn't it, pop off the cover to the throttle on the bars and make sure everything is attached in there.
Old 08-22-2011, 11:58 AM
Member #13890
i did that, and the cable seems to move fine, someone at work said it could be a return spring?. i dunno, i took the plastic cover off the side of the quad and there was a silver metal plate covering the place where the cable goes in. can someone please help me lol.
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 08-22-2011, 12:11 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
i would remove the carb and check the throttle vein ive had the vein retaining screws come loose and hold the throttle open.
Old 08-22-2011, 05:09 PM
Member #13890
will i have to readjust the carb after i check the screws? and where are they located?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 08-23-2011, 01:33 PM
Tehua's Avatar
Member #17970
Send a message via Skype™ to Tehua
My Sportsman 700 4x4 has the throttle cable on a wrong position and does accelerate when I turn right or left, it is dangerous.
Where can I get a schematic of the right way to install it?
Thanks!!!!!!!!!!! a lot!!!!!!!
Old 09-04-2011, 07:42 AM
joshr08's Avatar
Member #13071
first think i would check since you where riding and it was fine then after it sate for a few mins then when you restarted it to have the throttle at 50% i would check for a air leak could have just bounced around enough to bounce the carb lose just a bit it happens also check your choke cable to make sure it didnt get pulled
04 polaris predator 500 throttle
2003 polaris predator 500 broke return spring
2003 polaris predator 500 throttle cable
2011 polaris sportsman choke stuck open
atv throttle repairs throttle stuck
atv throttle sticking
atv throttle stuck
did polaris fix throttle sticking on rzr
polaris 50 stuck throttle
polaris predator throttle cover
polaris quad throttle
polaris throttle loose
polaris throttle stuck
polaris throttle stuck closed
polaris thumb throttle just pops
throttle stuck closed atv
throttle stuck on quad
throttle stuck open on atv
throttle stuck polaris
got stuck really bad lol jordaman17 ATV General Discussion 6 07-23-2011 07:12 AM
Got stuck ebaysnyper ATV General Discussion 14 07-22-2011 10:14 PM
Throttle stuck BigMacnFortMac ATV Repair and Maintenance 0 04-17-2011 12:51 PM
Twist throttle vs. thumb throttle? rsmith0801 Polaris Predator 5 03-22-2010 05:11 PM
Thumb Throttle VS Twist Grip Throttle Billster1955 Around The Garage 12 01-27-2010 07:54 PM
