Old 08-29-2011, 01:11 PM
jonnyb500's Avatar
Member #17829
pred mods!
Looking to make a custom air intake kit for my pred. Getting some 2.5 in stainless steel tube and going to bend it to fit in right. ill make a splash plate and other guards around the filter. What would be the best filter with a 2.5 in i.d.? i was looking at the kn ones. but theyre so damn pricey! id like alot of surcace area that will take a filtercharger.
When i rebuild the engine, will polishing the intake ports do me any good? theyre a little pitted from the casting.
not sure i want to bore out the cylinder but is there anything i can do to piston, cylinder, rod, shaft that will help?
Any way i can easily get low end power without sacrificing highend and mid power?
Old 08-29-2011, 04:54 PM
starpuss's Avatar
Member #16228
Why make a Custom intake? you will Boil the gas in the carb.
Yes porting and polishing helps lots
Old 08-29-2011, 07:19 PM
jonnyb500's Avatar
Member #17829
whatre you talking about?
anything else engine wise to do?
Old 08-29-2011, 07:41 PM
starpuss's Avatar
Member #16228
i was thinking you where going to move the carb back with a intake manifold.. that needs to stay Rubber.
so your going to Remake the air box boot?? Then a Filter Right on that ? a K&n should not be more then 50 bucks.
Old 08-30-2011, 11:54 AM
jonnyb500's Avatar
Member #17829
the carb isnt going anywhere! just a tube from the carb back to the area the original airbox is and a splash guard for the filter
Old 08-31-2011, 07:39 AM
Nate782005's Avatar
Member #3702
Hey Jonnyb500,
I have a custom intake (so to speak), but I used a spectre straight 3" tube, 45* bend tube and k&n filter wrapped in foam for a pre filter. I'm gonna switch over to a uni-filter soon, not crazy about a k&n. Piped and jetted it works awesome. I don't have any experience with any internal engine mods, but from what I've read they're not really worth it and only make very minimal power gains if any.
2005 Predator
Stage 1 Hot Cams CFM oil tank UM nerf bars and heel guards
Pro Aluminum skid plate and front bumper
Pure Polaris pipe K&N filter Jet Kit
Renthal bars, chain and sprockets Battery relocated
Civic style intake
1997 Trailboss
Jet Kit DG pipe
Modded cylinder fitted w/ 400 V-Force reed valve
Milled cylinder head
Namura piston and rings .040 over
Moose Racing gaskets
Old 08-31-2011, 01:05 PM
jonnyb500's Avatar
Member #17829
how did your cams and oil pan change your pred? notice any real differences? and did the 3 in tube fit under your seat easily without mods?
Old 09-01-2011, 04:26 PM
Nate782005's Avatar
Member #3702
Cams made a small difference. Oil tank is great, holds about 3.5 quarts and helps with engine temps quite a bit. The 3" tube fits pretty well under the seat. I really noticed a bid difference with the intake, jet kit and slip on pipe.
2005 Predator
Civic style intake
1997 Trailboss
Jet Kit DG pipe
Old 09-04-2011, 07:26 AM
joshr08's Avatar
Member #13071
hot cams are a waste of money. youll lose top end power. stock cams have been dynoed to show this lose in power on hot cams over stocks.
Port and polish also a waste of money on the fuji motor and hurts power. The fuji head is already to big for a stock motor. If your going to do anything in the motor do a 558 or 560 kit best bang for the buck. Run the stock cams and stock head porting as its almost perfectly setup to be ran as a 558-560 motor.
If your going to get cams for the fuji motor you need to get either hpd cams or webcams and tell them exactly what your doing with the motor. Also with those cams youll have to either know how to degree them for your motor or have a pro that actually knows the fuji motor and not just a polaris tech. With the fuji motor 1 tooth on the stock cams can mean even more money in valves and head work. There is very little to no room for error in this motor. A lot of people think this motor is like all the 450r's out there and they arent. Not even close. If your going to do the work yourself get a shop service manual and read and re-read. If you have other questions either pm me or find me over on my site. Polaris Pro Riders
Old 09-22-2011, 06:26 AM
Nate782005's Avatar
Member #3702
Sorry it's taken a while to respond, but why are HotCams a waste of money? Also what makes the Pred engine so much different from the 450's?
2005 Predator
Civic style intake
1997 Trailboss
Jet Kit DG pipe
06 polaris predator 500 cheap mods
2005 port and polished head polaris predator
how big of a difference does a polaris predator 500 air box mod
how to port and polish polaris predator 500
polaris predastor hot cams
polaris predator 50 exhaust porting
polaris predator 50 porting head
polaris predator head porting
polaris predator mods
polaris predator porting
polaris predator power kit
polaris predator stock cam identification
ported head polaris predator 500
porting and polishing predator 50
predator 500 port
predator 500 ported
predator 500 seat mod
Need help with a '05 Pred 500 makenzie71 Polaris Predator 7 04-29-2012 03:44 PM
new guy with 05 pred 500 bvisailer ATV New Members 2 12-10-2010 04:57 PM
06 pred headlights golfgttdi Polaris Predator 4 05-06-2010 09:23 AM
03 pred. 500 a few ??? RcWheeling Polaris Predator 2 04-15-2010 08:46 AM
07 Pred 20 hrs vs. 05 Pred TLD 100 hours Mardak Polaris Predator 2 07-21-2009 03:54 AM
