Old 09-05-2011, 11:44 AM
03predator's Avatar
Member #7495
Transmission Problem
Hello, i have an 03 predator 500. Clutch and trans works fine until i shift into 3rd gear. As soon as i hit 3rd, and i give it gas, it acts like theres a huge amount of slop in the drive train and then kicks back into 2nd gear. No grinding or noises. It sort of revs up then drops back to 2nd like 3rd gear isnt there but yet i can hit 3rd. Also it will not shift into 4th or 5th at all. I know its a trans issue. It is NOT a clutch problem. Im pretty mechanically inclined, just havent yet torn into the bottom end to find the culprit. Could it be as simple as a shift fork bent?
Old 09-05-2011, 01:32 PM
joshr08's Avatar
Member #13071
you have a bent shift fork known in the 03 fuji motors. Complete motor rebuild is in order. when you have it apart good time to big bore it and do the tranny upgrade in it as well. 03 trannys were known for being weak.
Old 09-05-2011, 10:23 PM
03predator's Avatar
Member #7495
When you say tranny upgrade, what exactly do you mean? Is there a later model tranny i use? Or a special ordered kit. More info is appreciated.
Old 09-06-2011, 12:20 AM
joshr08's Avatar
Member #13071
it will be a special ordered kit that will replace the problem parts
Old 09-06-2011, 07:48 AM
03predator's Avatar
Member #7495
Ok, do you have a website i can look into to find the upgrade? I appreciate your help.
Old 09-06-2011, 03:44 PM
joshr08's Avatar
Member #13071
I have been told Rath racing had them but you will have to call them to find out as they dont list much on there web site. Phone: 320.234.7223
Old 01-26-2012, 07:40 PM
RUBBERS's Avatar
Member #22634
i have same problem but only wont engage into 3rd or 5th will engage 1st 2nd and 5th help plz
03 predator 500 problems
03 predator 500 tranny
04 500 predator 4th gear slipping
04 predator 500 shift fork
3rd gear polaris predator
atv transmission trouble shifting
how change transmission gears: polaris predator 500
no 4th gear polaris predator 500
polaris 500 predator transmission rebuild kit
polaris atv transmission problems
polaris predatoer shifting forks
polaris predator 3rd gear failure
polaris predator 500 shift fork
polaris predator 500 transmission
polaris predator 500 transmission problems
polaris trans fork
polaris transmission problems
shifter fork for 03 predator 500
upgrading shift forks on 03 predator
Transmission problem in high Oldun ATV Repair and Maintenance 5 09-08-2011 02:10 PM
2002 Sportsman 700 transmission problem? smsparky36 ATV Repair and Maintenance 3 07-31-2011 06:33 AM
transmission max1212 ATV General Discussion 3 06-07-2011 03:00 AM
Looking For A Transmission Fourq2 ATV Parts for Sale 3 05-15-2011 07:14 PM
HELP - Transmission engagement problem airzima ATV Repair and Maintenance 2 06-17-2010 02:25 PM
