Old 09-09-2011, 04:26 PM
hvacmatt's Avatar
Member #16348
Unhappy refuses to start!!!!!
alright guys im out of ideas i recently jetting my pred. and starting having probleams with it starting untill the bike was warm then i would start right up well now i have gone back to the stock jet and needle and i still can not get it to start new plug(good spark) and fresh gas and im out of ideas still nothing any ideas
thanks, matt
2010 polaris sportsman 550 mossy oak
-3500lbs winch-
2008 polaris outlaw 525S
-uni filter
-swingarm skid plate
-nerfs
2006 polaris predator 500:SOLD:
-nerfs-
-full body skid plates-
-jetted-
-pure polaris pipe-
-UNI airfilter with prefilter
-blueice coolent-
2005 polaris trailboss 330
Old 09-09-2011, 07:56 PM
hvacmatt's Avatar
Member #16348
im starting to wonder if my timing is off some how!!!!!!
this seem right i look on the lil window and the T mark is off to the left side of the mark and the top cams seem to be fine??????
-3500lbs winch-
-uni filter
-nerfs
-nerfs-
-jetted-
-pure polaris pipe-
-blueice coolent-
Old 09-10-2011, 03:24 PM
joshr08's Avatar
Member #13071
why did you rejet? install a pipe? air filter? what jets are you running. i wouldnt think timing but i would check valve clearance
Old 09-10-2011, 03:41 PM
hvacmatt's Avatar
Member #16348
well i was untill the not starting issue started.. yes i have a uni Airfilter on the carb and a pure polaris pipe on it.. i was running a 170 main with the needle jet and openedthe mixture screw 2.5 open and did fine then it started acting up so i started tinkering and couldnt get anywhere so i figured i would put stock jet,needle back in and i still cant get the bike to start unless i pull start it... another ? lol shouldnt i see the T on the stator line up with the mark...... Thanks matt
-3500lbs winch-
-uni filter
-nerfs
-nerfs-
-jetted-
-pure polaris pipe-
-blueice coolent-
Old 09-10-2011, 03:52 PM
joshr08's Avatar
Member #13071
there are actually 2 sets of timing marks on the flywheel. dont ask me why because i dont know...lol. you need to look for the other set. now the timing marks actually only line up like every 27 revolutions or so. 170 with a uni and pure polaris is rich. i run the pp pipe and uni clamp on and will be dropping to a 165 main and thats on a 558 big bore. i ran a 170 and its way rich for that filter pipe combo. i would check your valves if the intakes are tight it will make it hard to start when cold. as for the a/f screw i have never even drilled my cap as you shouldnt have to mess with it if it idles fine and mine had no problems at idle even after all my mods. to me it sounds like you need to check valves and clean your carb maybe also check your fuel pump to make sure its pumping fuel. now you can check the fuel pump by pulling the vacuum line off the intake boot and suck on it if fuel flows its working.
Old 09-10-2011, 04:04 PM
hvacmatt's Avatar
Member #16348
i have already tore the carb down and cleaned it and getting good fuel from the pump do you happen to kno what the clearences are for the valves??
thanks
-3500lbs winch-
-uni filter
-nerfs
-nerfs-
-jetted-
-pure polaris pipe-
-blueice coolent-
Old 09-10-2011, 04:20 PM
joshr08's Avatar
Member #13071
Intake .006 (.15 mm) =/- .0019 (.05 mm)
Exhaust .010 (.27 mm) +/- .0019 (.05 mm)
Intake not more then .0069 (.20 mm) but not less then .0051 (10 mm).
Exhaust not more then .0119 (.32 mm) but not less then .0081 (.22 mm)
Old 09-10-2011, 04:40 PM
hvacmatt's Avatar
Member #16348
soounds good imma check them in a lil bit thanks is there a way to adjust them?????
-3500lbs winch-
-uni filter
-nerfs
-nerfs-
-jetted-
-pure polaris pipe-
-blueice coolent-
Old 09-10-2011, 05:13 PM
joshr08's Avatar
Member #13071
if they are off youll have to change the shims to do that you have to pull the cams
05 polaris predator 500 valve lash
06 polaris predator 500 not starting
2005 polaris predator 500 valve lash
2006 polaris 500 predator stock valve shim size
2006 polaris predator 500 valve adjustment
2006 polaris predator timing
adjusting valves on polaris predator 500
adjusting valves polaris trailboss 330
checking vacuum predator 500
how to set timing 2006 polaris outlaw
how to tell when to adjust valves on polaris predator 500
polais pipe on top of the carbulator for
polaris outlaw 525s not starting
polaris predator 500 outlaw starting problem
polaris predator valve adjustment
trouble shooting jets 08 polaris outlaw 525s
valve adjustment on polaris predator 500
valve job on polaris predator 500
2006 outlaw wont start when cold but will start when warm. heavyritefoot Polaris Outlaw 6 05-09-2011 01:42 PM
won't start Mike Malli ATV Repair and Maintenance 2 02-15-2011 05:36 AM
will not start hottrod ATV General Discussion 1 02-14-2011 07:44 AM
Wont start from a cold start. gramslam05 ATV Repair and Maintenance 5 11-28-2010 05:57 PM
Phoenix won't start with start button Dodgeboy Polaris Phoenix 1 10-19-2009 07:17 PM
