Old 09-09-2011, 04:43 PM
JAKnight1993's Avatar
Member #18506
07 Predator 500 front wheel bearings
The front right wheel bearing on my 07 Predator 500 wore completely out. Is this a replacable bearing or is it all one piece with the hub? I can't even press the darn thing off but maybe it's because I let it get so bad. If I need a new hub where is a good supplier? Thanks in advance for your help
Old 09-09-2011, 05:40 PM
Old 09-09-2011, 05:41 PM
03Grey500's Avatar
Member #14963
yes they are replaceable part they are similar to a skate board bearing and you can get them from a local dealer...as for the hub coming off it took 11.5 tons of force to break mine loose in a press and i ended up cracking my spindle what are 250 a piece so you might just be better off getting a new hub
Old 09-10-2011, 12:41 PM
Member #18506
Do you have an online site you recommend for buying a hub? And thanks for your response.
Joe
Old 09-10-2011, 03:16 PM
joshr08's Avatar
Member #13071
try using heat and press. when the bears wear out they make there own heat and really sets the bearing on the spindle. heat it up and then press it off might work better. if it was me i wouldnt buy new hubs of spindles for my predator. ebay has a ton of parts at a fraction of the cost of new and most are almost new as most people that bought these quads scared the shit outta themselves the first time out and didnt ride much after that. If you are able to get your bearing off i would replace them with the tappered bearings off ebay they last longer then stockers.
Old 09-10-2011, 03:22 PM
03Grey500's Avatar
Member #14963
I agree with joshr08 you just have to be careful with the heat because it can warp the hub from what i have been told. I also agree that ebay would be a good place to look or even a local dealer..i know the bearings are not a special order part a local hard wear shop should have them and the spindles are the same as a Honda
Old 09-10-2011, 03:26 PM
joshr08's Avatar
Member #13071
also another way to try it would be to heat it then put it right in the freezer then press it. just take your time i wouldnt just go buy a new one. you might as well break what you have before buying new. it might pop apart ....lol
Old 09-16-2011, 10:51 AM
Buckett's Avatar
Member #5518
Which model of Honda?
Old 09-16-2011, 05:55 PM
03Grey500's Avatar
Member #14963
to tell you the truth buckett i do not know all i know is they came out of a honda race quad that a local race team wrecked
they are only like 50 per spindle threw honda compared to polaris and for a high school student that works for me
Old 09-17-2011, 02:41 AM
Buckett's Avatar
Member #5518
Could be the 450r, I may go visit some old friends at the Honda shop later today and see what they have to say.
change front wheel bearings 07 predator
changing the front wheel bearing on a predator 500
front hub removal polaris 500 predator
how do you change a polaris predator 500 front wheel bearing
how to change polaris predator front wheel bearings
how to change wheel bearing on predator
how to press out spindles on polaris 500
polaris 500 front wheel bearing removel
polaris predator front wheel bearing removal
polaris predator hub removal
polaris predator wheel bearing size forum
predator 500 front wheel bearings
predator 500 wheel bearing
predator wheel bearing replacement
predator wheel bearings hard
predator wheel bearings when to change
replacing front wheel bearing on a polaris preditor 500
replacing front wheel bearings predator 500
wheel bearing front hub polaris preditor 500
Rear Wheel Bearings Michael0641 Polaris Sportsman 11 07-29-2011 12:48 PM
Need part numbers for all the front wheel bearings 02sportsman500 Polaris Sportsman 2 05-24-2011 05:38 PM
wheel bearings 2010 850 mkeddie Polaris XP 1 11-20-2010 04:12 PM
2000 scrambler front wheel bearings hugeyota Polaris Scrambler 0 10-17-2010 05:40 AM
05 sportsman front wheel bearings jmdpolarisman ATV Repair and Maintenance 6 02-20-2010 07:38 PM
