09-09-2011, 10:24 PM
Member #18521
04 predator 500 bored to 525 have questions
just recently purchased an 04 predator 500 that was bored to a 525, it also has an edelbrock carb, exhaust, and aftermarket radiator.
I made a dune trip with the bike this last weekend and it barely made it up sand mountain in 3rd gear. i was a little dissapointed by this. is it possible that the jetting is wrong? or could it possibly need to have a different cam?
any enlightment would be appreciated.
09-10-2011, 12:15 AM
Member #13071
there isnt a 525 kit for the predator
09-10-2011, 05:01 AM
09-10-2011, 07:34 AM
Member #18521
I'm just going off what the guy said who i bought it from. i am not positive but the smallest kit i seen online is a 550 kit. if that is the case i am really dissapointed in the bike now. jetted wrong? cams?
09-10-2011, 01:01 PM
Member #13071
could be a number of things i would check air filter fuel filter carb for jetting what gears you running what tires. if its a fuji motor it would either be a 558 or a 560 big bore. oh you said edelbrock carb didnt you....junk get a stock carb for easy tuning or you can get a fcr carb of a newer honda or yamaha of a 04-05 trx 450 honda carb. I run stock on my flat track bike. I also run stock cams in my race motor.
sorry for a short answer this morning as i was on the way out the door to work.
09-10-2011, 03:04 PM
Member #18521
ok i will tear into it tomorrow. i actually am getting rid of the edelbrock carb and getting a stock one put back on. mainly because the edelbrock carbs wear your thumb out in a hurry. do you know what jetting i should be running with the stock carbs?
09-10-2011, 03:06 PM
Member #13071
is it stock everything except for un-known engine mods? air box and pipe stock?
09-10-2011, 03:43 PM
Member #18521
No it has clamp on k&n filter and hmf piped.
09-10-2011, 03:53 PM
Member #13071
ok get your stock carb on and run a 165 main and needle clip 3rd notch down from the blunt end. then come back and tell me how much you love this bike
09-10-2011, 08:24 PM
Member #18521
I hope i can come back and tell you i love the bike.
2003 polaris predator big bore 560 reviews, 500 predator carb specs for big bore, big bore predator 500 review, big bore predator carb jetting, can a polaris predator 500 be bored to a 525?, edelbrock atv carb adjustment, edelbrock carb for predator, edelbrock predator, how does a polaris predator 500 carburetor work, outlaw 525 build, polaris atv predator 500 review, polaris predator 500 carburetor how to check the nedd, polaris predator 500 reviews, polaris predator 525 big bore kit, polaris predator edelbrock carburetor, polaris predator fcr carb, polaris predator sand, predator 500 questions, predator big bore 550 kit reviwe, quad polaris 525 los anjeles
