09-11-2011, 04:28 PM
Member #18584
New here
Hey all I'm new on here just thought I'd say hi.
Names James, I'm from Ontario Canada and I have a 500 Predator!
It has a small battery problem.... it seems to die shortly after connecting it??
Like I can start it let it run/idle for 10 mins, shut it off and it won't be able to restart itself??
I also noticed the fan seems to run excessively, like for 10 mins after shutting it off, but that shouldn't be enough to kill the battery should it? Maybe I'm due for a coolant change.
Any ideas for the battery drain?
Thanks guys.
James
09-11-2011, 04:30 PM
Member #13240
welcome to the forum james
09-11-2011, 04:40 PM
Member #18584
Thanks Jordaman, wheres Renfrew again, I know I've been through it.
09-11-2011, 07:16 PM
09-12-2011, 07:16 AM
Member #14963
could be your battery is shorting out that is what was happening to mine..just from it ideling the cable was moving just a bit to short out somehow just tightened up the battery cable
09-12-2011, 02:26 PM
Member #13071
i would flush and wash the radiator and blow it out also. Even on my race motor the fan doesnt run that long and i run it hard. As for the battery going dead like that i would run some tests with a multi meter and see if its charging properly. at idle it you should read somewhere around 15.9 volts or so and when you rev it up to about 4500 rpms you should see an increase in voltage up to about 14.5 volts or so. if your not seeing these numbers you need to start checking your charging system
09-12-2011, 02:50 PM
Member #13240
it's between ottawa and pembroke on the trans canada highway.
09-12-2011, 03:00 PM
Hello and welcome!
09-12-2011, 04:46 PM
Member #12642
Like Josh said use a multimeter to verify that it is infact charging properly. Might want to go through all the grounds to the frame with sand paper to make sure rust is not the problem. If all that checks out look at the voltage regulator, I had the same problem as you, a simple test, after the quad has been running for awhile put your hand on the voltage regulator, if its cold to the touch you will need to replace it.
09-13-2011, 06:01 PM
Member #18584
Awesome guys! Thanks for the replies!
It is definitely charging at 14.5, so I will check the voltage regulator (where is it by the way?) and look for shorts or bad grounds.
And doing a coolant flush is top priority!
Thanks again!
James
04 polaris predator charging, polaris atv, polaris predator charging, polaris predator charging 16 volts, polaris predator charging system, polaris+atv forum, predator radiator flush
