Old 09-12-2011, 03:17 PM
neandrathal's Avatar
Member #18595
Predator wars
Lol im new I have an o5 love it too death, I have sway in rhe front end when at high speeds anyone got a clue brand new balljoints on the way...................will add photos soon allballs allballs bearings front end custom rad-scoops custom stainless-rad-grill twistys throttle biggun rev box, after,market bars N stem, ordered big bore, halos an +2 a-arms
Old 09-12-2011, 04:41 PM
DARKPHREAK's Avatar
Member #12642
Piss poor grammar and punctuation but your user-name explains it all...
What exactly is your question?
Old 09-12-2011, 04:55 PM
Member #18595
Dont be rude senior, im using my phone currently............. I need help kmowing if every predator has wild steering at high speeds or if my balljoints an tires are the issue for for the horrid steering?
Old 09-12-2011, 05:07 PM
joshr08's Avatar
Member #13071
check your alignment on the front end and change your suspension. putting the quad to far in the air will make it very twitchie. try to lower the front end a bit by adjusting your shocks.
Old 09-12-2011, 06:05 PM
Member #18595
Thank you bud
dy ill give it a shot in the morning..................
Old 09-13-2011, 05:03 AM
1M800's Avatar
Member #635
Also check for play in the front wheel bearings, rear axle bearings, and shock bushings. They are all common problems and all affect the handling. I have changed them all and the handling is 10 times better than it was when I bought it this spring. It could still be better. I should try lowering it down but won't that also make the front end softer??? I already bottom it out when jumping.
2005 Predator 500, Holeshot HD's, Pure Polaris slip on, 1" bar riser. (Mine)
2005 Sportsman 700 EFI, EPI clutch kit, Aaen megaphone muffler, 27" Highlifter Outlaws. (Mine)
2002 Sportsman 500 H.O. Remington Edition, 26" PXT's. (Wifes)
2001 Trailblazer 250 (Son #1)
2007 Phoenix 200 (Son #2)
2003 Predator 50 (Son #3)
Old 09-13-2011, 05:14 AM
Member #18595
Thank you hombre got all my balljoimts yesterday gonna hit it hard today amn hopefully be done but thw rear axle bearings are a lil worn are they hard too change?
Old 09-13-2011, 05:46 AM
1M800's Avatar
Member #635
They are not too bad but sometimes the housing is bad too. Mine has a new housing and bearings now. Good luck!
Old 09-13-2011, 03:53 PM
joshr08's Avatar
Member #13071
1m800 if your bottoming out you need to have your shocks done for your weight/riding style.
Old 09-13-2011, 04:01 PM
Member #18595
Nobottoming out I currently have the speed wobbles but i put new balljoints today an getting tires an tie rods in the next few, do you gentlemen know whom may have a good cone airfilter? for the ram intake
04 polaris predator tire pressure
balljoints polaris predator 500
lowering front end predator 500
polaris 250 trailblazer lowering kit
polaris predator 50 alignment
polaris predator 50 tire pressure
polaris predator 500 alignment
polaris predator 50cc tyre pressure psi
polaris predator air pressure
polaris predator alignment
polaris predator bar riser
polaris predator common problems
polaris predator front end
polaris predator front end]
polaris predator front tire pressure
polaris trailblazer 250 lowering kit
predator 500 soft suspension
predator 500 with front endshake
tginking about lowering my predator 500
tire psi polaris outlaw
