09-16-2011, 02:21 PM
Member #18720
starter solenoid
just got an 03 predator someone hacked the wireing and put a universal solenoid off like a truck or something. lol but i replaced the whole wiring harness and bought a used solenoid off ebay. my question is... is there suppost to be power comming out of the 2 wires that are comming out of the solenoid i used a test light and there isnt. and i know it has power from the battery because i can jump the battery to the starter wire and it will turn over.
09-16-2011, 03:07 PM
There should be power in those wires only when the start button is pressed on the handle bar. One wire is a ground, the other is just a standard 12v power source running through the start button.
Since the battery side of solenoid is always hot, those wires can only be hot when trying to start it, otherwise the starter would be running all the time.
09-16-2011, 03:17 PM
Member #18720
so what do you think it could be i heard there circuit breakers in the harness i bought a used harness maybe that?
09-16-2011, 04:44 PM
Is there power at the start button?
09-17-2011, 03:34 AM
Member #18298
im under a different name no theres no power at the switrch
09-17-2011, 01:43 PM
Member #12642
Check to see if the pins are making contact.
09-17-2011, 02:23 PM
Member #18298
yea everything is plugged in fine went over it with wd 40 in all the plug to make sure nothing is blocking it I don't even have neutral light up no power past the solenoid I bought a used solenoid so I bought a new one it probably be hear tuesday I hope it that the say if you cross terminal and to jump start it and works probably bad solenoid I use a wire for the battery to jump over the solenoid and got neutral light to come so guessing that bad solenoid
I am here: http://maps.google.com/maps?ll=43.498036,-70.960813
09-17-2011, 02:37 PM
I dont think its the solenoid. I dont think this new one is going to fix it.
If you are not getting power to the solenoid from the start button when you press it, then of course it doesnt matter what solenoid you put in, it isnt going to work. You need to start tracing wires. Can you turn the headlights on and such when you turn the key on.
09-17-2011, 02:55 PM
Member #18298
right I understand hat but if the power don't get past the solenoid don't you think it has to me that cause after the battery the next thing in line is solenoid what's your thoughts
I am here: http://maps.google.com/maps?ll=43.498107,-70.960253
atv no power to solenoid, celinode block, how do you replace starter solenoid switch on polaris atv, how to put wires back on solenoid switch polaris atv, how to test polaris starter, how to test polaris starter relay, polaris predator 500 solenoid hook up, polaris predator starter relay, polaris predator wiring diagram, polaris solenoid wiring, polaris starter celinode, polaris starter relay, polaris starter solenoid, polaris starter solenoid diagram, polaris starter solenoid wiring, solenoid wiring diagram polaris atv, starting silinoid polaris quad, wire diagram for starter selinoid for a polaris, wire diagrams for polaris predator, wiring diagrams for starter solenoid on a 2003 polaris predator images
