Old 09-18-2011, 06:56 AM
kilgore1910's Avatar
Member #18769
Thumbs down speed limiter
I just got my granddaughter a polaris 90 predator and the previous owner has removed the rpm limiter and i need to slow it down. how can i reverse this, what does it involve etc.
Old 09-18-2011, 03:29 PM
neandrathal's Avatar
Member #18595
Throttle Stop Speed Control System
Adjusting speed at the CDI is the recommended method of speed control, but the throttle stop system may also be used. The following procedure allows you to control how far the throttle opens.
1. Loosen the jam nut
2. Turn the screw inward to reduce speed or outward to increase speed.
3. Tighten the jam nut after adjusting
Check out my preddy
Old 09-18-2011, 04:00 PM
Member #18769
rev limiter
the person i got it from unpluged something in the cdi box i would like to put it back. regrads tom
Old 09-18-2011, 04:10 PM
Member #18595
ok heres what they did you just need too reverse the situation as well as check the cdi screw should be all the way in or most of the way.....................if you need the parts go too cheapcycleparts, or bikebandit they carry oem parts for these machines;;;;;;;;;;;
their is a jumper on the CDI box.
1.Remove the CDI and its rubber mounting strap from the mounting tab, which is located on the frame bulkhead near the steering post. It can be accessed through the left front fender.
2. Remove the two screws from the jumper to remove the jumper. Reinstall the screws.
3. Reinstall the CDI and mounting strap onto the mounting tab.
Check out my preddy
Old 09-19-2011, 07:06 PM
Member #18769
speed limiter
thanks for your help regards from kilgore1910
Old 09-19-2011, 07:20 PM
Member #18595
no problem enjoy and be safe................
Check out my preddy
Old 01-26-2012, 07:19 PM
Chunkyrud98's Avatar
Member #22691
How do you make a ATV 50cc faster
2012 polaris outlaw 50 jam nut and screw size throttle
atv throttle limiter
blazer 90 rpm limiter
do you need to reinstall the screws on cdi after removal of jumper predator no help
does adjusting throttle slow an atv down?
does the screw by the throtle on atv slow it down
how slow does a sportsman 90 go
how to adjust speed limiter on polaris sportsman 90
polaris 250 speed limiter
polaris 90 rev limiter
polaris predator 90 rev limiter
polaris predator 90 speed control
polaris predator 90 what is the slowest speed
polaris scrambler rev limiter
polaris speed limiter
polaris speed limiter 90
polaris trailblazer 250 decrease speed
polaris trailblazer 250 rev limiter
remove speed limiter on sportsman 90 atv
ricks polaris 90 cdi rev limitier remove
rev limiter problem mikechef13 Polaris Trail Blazer 7 06-30-2011 06:04 PM
92 rev. limiter avrg. Joe ATV Repair and Maintenance 1 02-15-2011 01:39 PM
Limiter problem I think. Lacomo Polaris Trail Blazer 1 07-09-2010 08:58 AM
Throttle Limiter? SPLMAN Polaris Scrambler 3 05-05-2010 06:44 PM
rev limiter??? on sportsman 500 CrazyFazy Polaris Sportsman 2 01-03-2010 09:05 PM
