My suggestion there would be just get yourself a manuel would make life alot easier when you have the wiring diagram an the bike side by side an you can check on bikebandit.com too see if the diagram is on there in the oem section but bwfore you go spending money go threw your wiring off thw fan an look for anything grounding you could have something arching on occasion too prevent the fan from working properly.....
if it need go deeper id look into the temperature sensor or sending unit
Check out my preddy
