09-25-2011, 03:07 AM
Member #13890
i got nothing
lol just like the title says, i was riding last night and the headlights started acting weird, when i was on the throttle they were dim, off the throttle idling they were bright, i stopped to have a smoke and check it out, tried starting it, nothing. no headlights, no neutral light , nothing on the starter button, hooked up a rope to it and pulled it with my buddys scrambler and it pop started (we were in the woods), got it back to the house and shut it down and tried the starter button again and still nothing. any thoughts guys?
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
09-25-2011, 04:23 AM
Member #13071
sounds like a charging or regulator issue to me. time to get out the multimeter and start running some tests.
09-25-2011, 05:11 AM
Member #13890
what should i be testing? or looking for?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
09-25-2011, 05:13 AM
Member #13071
test your battery with quad off. then test it with quad running (i know youll have to pull start it) not running you should be at 12.5 or so. if not charge or pull start it then you should be at about 14 or so volts with it running at about half throttle or so. this will tell you if your charging your battery or not.
09-25-2011, 05:21 AM
Member #13890
where is the regulator located? and the charging (stator)? are these parts i can get or are they dealer only parts?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
09-25-2011, 05:25 AM
Member #13071
regulator is located under the battery tray stator is behind flywheel both can be bought from anywhere that sells polaris atv parts i believe.
09-25-2011, 05:29 AM
Member #13890
the regulator sounds easy enough, is the stator something i could change out myself?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
09-25-2011, 05:32 AM
Member #13071
yeah only things you would need is a electric impact a flywheel puller and gaskets and oil as youll have to drain the motor.
09-25-2011, 05:55 AM
Member #12642
Easy way to test voltage regulator. Jump start the quad with a battery pack, run it around the yard 10 minutes, put your hand on the VR, if its cold you need to replace it.
09-25-2011, 06:03 AM
Member #13890
good tip thanks ill try that
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
2003 polaris predator 500 no battery voltage, 2003 polaris predator missing about half throttle, how to start a 500 predator with silonoid, polaris predator 500 not charging battery, polaris predator charging, polaris predator charging issues, polaris predator voltage regulator, polaris voltage regulator test, polaris+predator+smokes+when cold, predator 500 charging issue, predator 500 not charging test, predator 558 battery
