09-28-2011, 09:50 AM
Member #18371
predator 500 hard to start cold
my predator 500 is hard to start when it sits over night but after you get it started it starts fine the rest of the day the valves are fine any ideas
09-28-2011, 10:57 AM
Member #15429
predator
either fuel pump going bad or carb needs rebuild
09-28-2011, 05:20 PM
Member #18371
well i worked on it tonight my battery keeps running down so i tested wires and found two brown wires fell out of connector to the voltage regulator i hooked them back up and tried to start it it starts easier and idles better it must not have had enough juice to fire it cold.
09-28-2011, 05:42 PM
Member #15429
predator
well ok gd at least u didnt have to spend any money
10-14-2011, 09:33 AM
Member #18371
well okay not the problem still starts hard when cold and starts fine when it gets warmed up
10-15-2011, 01:00 PM
Member #13071
any aftermarket parts? air filter? pipe? could be running lean also check and make sure the choke is working correct.
10-15-2011, 07:28 PM
Member #18371
hard start
i think choke is working cause after you get it running been riding it for a while while it is idling if you pull choke out it dies, another thing when it is running it sounds like it is idling too high but then it slows down and dies only after market parts are a header pipe and a pure polaris slip on
10-16-2011, 05:01 AM
Member #13071
air leak would cause the high idle and dirty carb will make it die.
04 polaris predator not starting when cold, 04 polaris wont start cold, common causes for hard starting when cold atv, how to start a cold polaris predator, my polaris predator wont start in cold, polaris predator 500 cold start, polaris predator 500 hard start when cold, polaris predator 500 hard to start, polaris predator hard start, polaris predator hard start cold, polaris predator hard time starting, polaris predator hard to start, polaris predator runs bad when cold, predator 500 hard to start, predator 500 sat for a while and wont start, predator tough to start, predator wont start in cold? ?, start a cold quad, what causes my predator 500 to start hard and make noise, what will make my polaris predator 500 run lean
