Old 10-01-2011, 05:01 PM
neandrathal's Avatar
Member #18595
chain and sprocket
i ordered a 15 tooth sprocket wondering if i need a larger chain for it or do i use the same chain as the 14 tooth sprocket?
Check out my preddy
Old 10-01-2011, 06:02 PM
It's always best to replace both sprockets and chains together, and that allows you to order a longer chain and cut it down to size.
With that said, usually you don't need to add links for one tooth on the countershaft.
Old 10-01-2011, 06:26 PM
Member #18595
awesome what size sprocket for the rear would be proper for the new 15 tooth? lookin for more low end torque?
Check out my preddy
Old 10-01-2011, 07:21 PM
What was stock? 14/38?
14/38 is a ratio of 2.71
15/38 is a ratio of 2.533
The 15 is the wrong sprocket if you want more low end. The 15 is going to take away low end and give you more top end speed.
The bigger that number gets, the more low end you will get, at the sacrifice of top end speed.
So if you use the 15 front, you would need at least a 41 to break even.
A 15/41 is a 2.73.
So if you havent noticed, going one up on the front is about the same as going three down on the rear. The opposite is true. Going one down on the front is about the same as three up on the rear.
So if what you want is low end, I would reconsider using the 15, and go with a 13 instead. Going with a 13/40 is going to be a very noticeable low end improvement. I probably would go any more the a 6 tooth difference then stock (and one tooth on the front counts as 3)
The biggest change I would go is a 13/41. You could go with a 13/38 (stock rear) and still have a slightly noticeable difference.
Here is a chart so you can see what I am talking about: -->> http://www.jtsprockets.com/fileadmin...tgearratio.pdf
Old 10-01-2011, 08:28 PM
Member #18595
awesome i was all turned around well since i have the 15 tooth looks like ill be goin for top end for now lol thanks for that nifty chart and your help
Check out my preddy
how do i get more torque out of my polaris predator 500
how to get more bottom end torque on a predator 500
how to get more low end torque polaris predator
how to get more torque on a predator 500
how to give my polaris predator 500 more bottom end
how to give my polaris predator more bottom end
how to make predator 500 more torque
need more low endout of polaris predator
polaris predator 500 front sprocket size
polaris predator chain and sprocket low end
polaris preddy sprocket
predator 500 15 tooth
predator 500 15 tooth front
predator 500 best chain
predator 500 sprocket 15 38
predator sprocket chain
sprocket for more tourque 03 predator
what size is a polaris predator chain
what size is the shaft for the front sprocket on a polaris predator 500
what to the front sprocket size on a predator
Recommended chain and sprocket brands? sinful ATV Repair and Maintenance 6 08-19-2011 09:58 AM
6x6 Chain and Sprocket replacement CosmoNont ATV Repair and Maintenance 3 05-31-2011 08:10 PM
Hy-vo chain upgrade for silent chain/reverse chain 1997scrambler4x4 ATV Repair and Maintenance 2 03-10-2010 08:26 PM
