Old 10-01-2011, 05:22 PM
Ta2edphreak's Avatar
Member #13890
voltage regulator
i need a voltage regulator, im having trouble finding one, anyone know a replacement or where i can get one cheap, its for a 2003 predator 500.
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
Old 10-01-2011, 06:42 PM
neandrathal's Avatar
Member #18595
tons on ebay buddy look for regulator rectifier
Check out my preddy
Old 10-02-2011, 03:06 AM
Member #13890
ok will any other year work with my 03?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 10-02-2011, 04:45 AM
Member #18595
yes most of them are all the same some just have an insert in them, that is removable just make sure you buy it from someone whom accepts returns unless you buy it new i have a procom one i paid 60 for that i like alot lil extra power out of it
Check out my preddy
Old 10-02-2011, 11:31 AM
Member #13890
forgive me, whats the insert for? so a voltage regulator for an 05 tld will work on my 03?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 10-02-2011, 12:03 PM
Member #18595
The insert is in one of the plugs whither you need or not it just slides in an out, stay away from tld stuff unless yours is a tld but all years should interchange
Check out my preddy
Old 10-02-2011, 02:23 PM
joshr08's Avatar
Member #13071
i would stick to 03-04 or 05-07 depending on what yr yours is then theres no way it wont fit. in 05 they changed harnesses
Old 10-02-2011, 02:27 PM
Member #13890
so if i get a rectifier/regulator that isnt oem then it will be more of a performance mod?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
03 polaris predator 500 resistor rectifier
2003 polaris predator 500 resistor
2003 polaris predator 500 voltage regulator
2003 polaris sportsman 500 voltage regulator does it have one?
atv voltage regulator test
how do i tezt the regulator on a polaris predator
how do you test a voltage regulator on an atv
how to test predator 500 rectifier
polaris atv voltage regulator
polaris predator 500 rectifier
polaris predator voltage regulator
polaris voltage regulator test
predator 500 procom rectifier
predator rectifier does it work
regulator polaris atv
test polaris regulator/rectifier
wher is voltage reg polaris outlaw 50
will a 03 regulator work on a o5 polaris predator
voltage regulator green machine ATV Repair and Maintenance 4 01-31-2012 05:21 PM
Voltage Regulator Quantum673 ATV Repair and Maintenance 8 09-20-2011 08:46 AM
XP voltage regulator crimson850 Polaris Sportsman 10 07-14-2011 08:15 PM
Voltage regulator Mcoffey24 ATV Repair and Maintenance 5 05-09-2011 03:06 PM
95 Sportsman Voltage Regulator???? craig_ryan ATV Repair and Maintenance 6 12-20-2010 12:55 PM
