10-03-2011, 05:42 PM
Member #18371
need help on predator 500
okay tonight i removed the cover that has all the elctronics for the flywheel and it was full of oil i didnt think oil should be around fly wheel let me know if polaris is supposed to my ltz 400 didnt have oil around fly wheel.
10-03-2011, 05:44 PM
Member #13240
it should not
10-03-2011, 05:54 PM
Member #18371
oil in cover
would this cause it to start hard when it sets over night but start right up when its been ran for awhile
10-03-2011, 06:07 PM
Member #13240
you wouldn't think so. after a ride it would splash oil through the electronics, so you'd think it would be easy to start after sitting if the oil caused anything.
10-03-2011, 06:26 PM
Member #18371
oil in cover
some has a aftermarket head pipe and a pure polaris slip on does it need to be jetted. Okay this is the whole story it sets over night it is very hard to start, you eventualy get it started, will not idle, you ride it for a while still wont idle, while ur going down the road u can pull choke out and it doesnt affect how t runs but if u are idling and pull choke it will dies sometimes it will idle sometimes it wont if you shut it off it will start right back up no problem, it runs good when you get it started. it has new air filter, carb cleaned, and new spark plug. let me know any ideas
03 predator500 lift kit, hard clutch on 500 predator, lifting a polaris predator, pics of 2008 polaris predator 500 oil filter, polaris 500 predator shuts off hard, polaris predator 500 lift kit, polaris preditor 500 troubleshoot, what headlights predator 500 have
