Big Problem
I have a 03 predator. My chain broke and it took the chain guard out, put a hole in the stator cover and a small crack in the engine case itself. I put a new stator cover on and epoxy over the crack. When I fired it up it's leaking BAD!!!! I dont know anyone with a tig welder and there are no places close to take it to so I can get a new case installed. Are there any good suggestions to put on the crack to seal it? There is also a small crack in the case where the clutch rod( I think that's what it is) goes into the case as well but it doesn't look like it's leaking from there. How much oil pressure is in the stator case? Thanks..
