10-04-2011, 05:25 PM
Member #18371
hard to start after sitting over night
predator 500 has aftermarket headpipe pure polaris muffler, stock air box, and stock carb no jet kit would this cause it to start hard when it has sat over night but after you get it started it starts fine all day.
10-05-2011, 04:58 PM
Member #12642
Bad plug?
10-14-2011, 06:19 AM
Member #18371
still need help
still need help PLEASE
10-28-2011, 10:33 AM
Member #19342
ever get this solved? Just a thought it could be a slow leaking needle and seat in the carb that once it sits over night its flooded but throughout the day it leaks slow enough that it doesn't cause a problem.
12-02-2011, 02:37 AM
Member #20996
I have the same problem I was told valve job or there is some spring that is causing it to not get compression well I got a heat gun I set it so it is pointing at the motor on the exhaust side for about ten min. And it starts every time with no problem if it coola I have to do it again but it starts when I put just a little heart to it
12-02-2011, 05:16 AM
Member #14933
I'd say valves
2011 xp850
Stealth Snorkels
30/11/14 zillas
14" Polaris pro wheels
Guru bumper
Mud tubez stereo
Epi clutch kit
Cycle country plow
3000lb winch
12-02-2011, 05:10 PM
Member #13071
valves.
2006 polaris predator hard to start, hard starting 2011 pollaris atv, hard starting atv, hard starting atv with carberator, hard starting predator, hard to start after over night, polaris atv hard starting trouble, polaris atv hard to start after sitting for month, polaris predator 500 exhaust not sitting, polaris predator 500 hard to start, polaris predator exhaust leak, polaris predator hard to start, polaris scrambler 500 hard to start, predator 500 hard to start, predator 500 is hard to start, predator is hard to start, predator tough to start, preditor 500 hard to start, tough starting atv, what would cause a polaris predator to be hard to start
