Old 10-05-2011, 07:10 PM
cooper99's Avatar
Member #14931
turns over has spark, but no start!!
i have a 2006 tld predator- I went to start it, it made a loud backfire then wouldn't start. it turns over but wont fire up
is this CDI, bad wiring, valves, spark plug, compression? ??
i have never ran into an electrical problem, and am still coming along with bike and quad mechanics.
Old 10-05-2011, 07:22 PM
thomaseweber's Avatar
Member #2655
Getting gas. Could be when back fired it shear magneto key that tell the plug when to fire.
Sent from my PC36100 using Tapatalk
Hey Ya'll watch this- if i say this i'm getting Stuck.
2004 Ford F350 Lariat 4x4 6.0 Litre FX4
2004 Ford Ranger 4.0ltr 4x4 5spd
2009 Polaris sportsman 850xp
Old 10-05-2011, 08:09 PM
cooper99's Avatar
Member #14931
so what do you suggest?
Old 10-06-2011, 08:43 AM
Member #2655
You have to find out when your spark plug is firing if it is firing when its top dead center magneto key should be fine but if not firing top dead center you have problem.
Old 01-02-2012, 06:13 PM
stang7tl's Avatar
Member #21650
my sportsman is doing the same. was running then loud as hell backfire now wont start engine getting gas fine and has spark so if it is the key what is the fix will pull it apart tomorrow thanks
Old 01-03-2012, 07:34 AM
Craig's Avatar
Member #3065
Will it start if you open the throttle a small amount, then if you let off it dies? If so then it's likely the throttle safety switch inside the throttle thumb housing, pry that open and adjust so that the contacts are not touching and it should stay running.
03 predator 500 wont start it gets gas and spark and has good compression
2003 polaris predator 500 wont start its getting gas and spark
2004 polaris sportsman atv turns over but wont start
2009 polaris 500 sportsman safety switches that would cause it not to fire
atv backfires and loud when running
atv has spark but wont stay running
my atv engine turns over but doesnt start
my polaris ranger wont start
polaris 500 spark but no fire
polaris 500 sportsman will not start turns over and backfires
polaris predator turning over but will not start up!
polaris ranger died and will not start
polaris ranger turns over but will not start
polaris ranger will crank but no sparrk
polaris ranger will not start
polaris ranger will not start fires
polasis 500 sportsman will mot start turns over and backfires
quad getting spark but not firing
why do the spark plugs have no spark on my polaris 700
Sportsman 600 wont start but turns over Rscheydt ATV Repair and Maintenance 5 02-10-2011 08:11 AM
HELP.... 04 1/2 efi 700 won't start, turns over though newbie7146 ATV Repair and Maintenance 3 01-31-2011 02:39 PM
Has spark, won't start jbdlc Polaris Sportsman 3 09-28-2010 04:37 PM
2003 Preditor 500 wont start!! turns over has Spark PLEASE HELP Xukh ATV Repair and Maintenance 13 02-19-2010 06:06 PM
95 Explorer 400 start and die (spark) only some times CDI? THANKS!!!!! Highly Boosted ATV Repair and Maintenance 10 12-17-2009 05:29 PM
