Old 10-10-2011, 12:49 PM
ridemhard's Avatar
Member #3442
torx bit size
Does any one know the size of the torx bit used to take of the bolt holding the front brake pads on? Thanks for your help.
Old 10-11-2011, 05:49 PM
JFoley001's Avatar
Member #18462
What year. 05 and 07 use hex bolts.
2005 Predator 500 TLD K&N Dyno Jet Pro Armor
2007 Predator 500 CUSTOM CREATION by REDNECK2725
Old 10-13-2011, 12:26 PM
ridemhard's Avatar
Member #3442
its an 03 so they have the six point torx bit. I think its a T-50 but not sure.
Old 10-15-2011, 01:01 PM
joshr08's Avatar
Member #13071
i would check mine but i dont run front brakes on my predator.
Old 10-30-2011, 08:17 AM
etachell's Avatar
Member #11757
My machine is an 03 and the bolts from the steering knuckle to caliper bracket are regular hex bolts. The bolts from the caliper bracket to the caliper are not Torx, but allen head bolts.
An M9 allen wrench fit best, but I felt was a bit loose. A 3/8 allen wrench might also fit, but mine wouldn't fully seat.
Eric
are the hex bolts on a predator 500 metric
oil plug wrench size polaris predator
polaris atv oil bolt hex size
polaris brake caliper torx bolt
polaris caliper torx bolt size
polaris oil torx
polaris predator bolt sizes
polaris predator brake dimensions
torx m9 screw for brake
torx size for a polaris rear caliper
what is the allen head screw for on brake caliper on polaris predetor
what is the torx bolt on polaris brake caliper
what size allen wrench will fit my predator brake caliber
what size bit for polaris oil plug
what size brake bolt on the polaris predator 500
what size hex wrench for polaris rear brake
what size wrench for polaris oil plug?
What size chain do you have? neandrathal Polaris Predator 5 11-29-2011 04:00 PM
????? size 4x4camaro ATV Wheels & Tires 3 04-30-2011 06:56 PM
Unsure about four black torx tldanos ATV Repair and Maintenance 11 11-02-2010 03:02 PM
Will This Size Work? SnoGhost ATV Wheels & Tires 3 07-16-2010 04:27 AM
Oil plug size for 850 xp BTH Polaris XP 2 04-19-2010 09:06 AM
