Old 10-10-2011, 05:20 PM
mudkicker's Avatar
Member #15075
Carb Jetting
I have a HMF Iron Man exaust.. My bike is stock besides that, I have a jet kit on the bike right now and it runs good but It pops and I was wondering if that's good and I also with that exhaust what size jet is recommended for that type of exhaust?
Old 10-11-2011, 05:33 PM
JFoley001's Avatar
Member #18462
Hello!
When you say it pops, is this symptom when on the throttle, on decel, all the time? Are you smelling unburnt fuel? What does your plug look like? Is your valve lash correct?
2005 Predator 500 TLD K&N Dyno Jet Pro Armor
2007 Predator 500 CUSTOM CREATION by REDNECK2725
Old 10-11-2011, 07:02 PM
mudkicker's Avatar
Member #15075
When I decelerate
Not sure if I smell unburnt fuel or just the exhaust that barreling out.
I will check my plug soon
What is valve lash?
Old 10-11-2011, 07:37 PM
JFoley001's Avatar
Member #18462
Smile
Guys feel free to step in and correct me if I'm wrong but just about every atv/ dirt bike I've ever owned popped a bit on decel when tuned right. It's just that little bit of unburnt fuel from throttle burning in the hot exhaust pipe. Is it affecting performance? I guess it all depends on how much its popping. If I had to guess I would say that mine pops 2 times between full throttle on its way down to idle. Im no expert on this by any means. Valve lash is the clearance between the cam lobes and the valve bucket when piston is at top dead center. Valvecover has to come off to check this. I wouldn't go that far until I checked compression and I would only do that for a low power or smoking issue. I think you are okay unless you are noticing power or performance issues like bogging or missing.
Old 10-11-2011, 07:50 PM
JFoley001's Avatar
Member #18462
ATV Carburetor Jetting Instruction - ATV Technical Articles
Here's a little guide to jetting, but just an introduction. I think you prob have a .165 or .155 main jet now. The only way to know for sure is to pull it and read the number.
Old 10-12-2011, 05:05 AM
mudkicker's Avatar
Member #15075
No
The bike has no lack of power at all
It's about like yours, it'll pop about twice during decel
I wanted to hear it from someone who knew, I don't know much about jetting
I bought the bike from a guy who already jetted it.
I'm gonna pull it off and take a look soon as I get a chance
Old 10-15-2011, 01:06 PM
joshr08's Avatar
Member #13071
exhaust popping on decel is usually from either a few things. cold air getting into your exhaust either a leaking exhaust flange or gasket. my race build pops twice every time i go from full throttle to closed every time. i wouldnt worry to much about it as long as your plug looks good.
Old 10-28-2011, 05:42 AM
mudkicker's Avatar
Member #15075
Pulled my plug off yesterday and it looked like it is burning fine, it was probably the original so I changed it
Thanks for y'all help and advice
______________________
05 Predator
10 Sportsman 550
06 polaris predator 500 carb ajusutment
2005 polaris predator 500 carb settings
2007 polaris predator 50 carb adjustments
best jetting 06 polaris predator 500
carburetor tops polaris predator
polaris carb main jet
polaris predator 50 jet
polaris predator 500 carburetor jet
polaris predator 500 carburetor settings
polaris predator carb jetting
polaris predator carb rejet
polaris predator carb smoking
polaris predator jet guide
polaris scrambler poping out of carb
predator 500 pop idle
predator jetting polaris
what does the power jet do in a polaris predator 500 carberator
what kind of carburetor does my polaris scrambler
where is the power jet in a polaris predator 500 carb
Carb Jetting Help eazytony27 Polaris Scrambler 7 04-17-2011 05:14 PM
aftermarket exhaust carb jetting? atvman2010 ATV Repair and Maintenance 0 02-06-2011 06:35 PM
Carb Jetting setting question cadpat Polaris Sportsman 3 12-28-2010 07:33 PM
05 Sportsman Carb Jetting AZDesertRat Polaris Sportsman 5 07-30-2010 09:41 PM
jetting carb on 2008 outlaw 450 92lowtoy ATV Performance Modifications 1 06-22-2010 06:49 AM
