Old 10-17-2011, 01:37 PM
Minnesota's Avatar
Member #15540
Fan not turning on
The past couple rides I have done the fan has not come on. If I dont let it idle when I stop am I ok with running it this way for another trip? I figure as long as I keep moving air will be moving through the radiator and keep it cool.
Old 11-11-2011, 12:23 PM
SLIMSHADIE's Avatar
Member #6880
I had to replace a sensor on mine. It had a broken wire. Only noticed it when installing the new one. Its on the back of the radiator, by the coolant overflow tank. Bought new one from the dealer.
2010 Laredo 291TG
2006 Dodge 5.9L CTD Megacab
2005 Polaris Predator TLD 500
2005 Polaris Predator 90
2004 Suzuki LT-Z250
Old 11-11-2011, 04:05 PM
joshr08's Avatar
Member #13071
i wouldnt ride it with a fan thats not working. most times my pred only runs 10-15 mins before my fan is on and at the track it pretty much runs non-stop
Old 11-23-2011, 07:02 PM
Lowrider06's Avatar
Member #20728
i had the same issue, if i am going all the time it would never over heat until i would stop then the little red heat light would come on....well i put in new sensor, checked the plug with a battery to make sure fan actually works and it did, but still had issues. Well figured it was a wire but couldnt find it, so a buddy of mine suggested putting in adjustable fan switch Hayden Automotive 3651 - Hayden Electric Fan Controls - Overview - SummitRacing.com ive been happy and not have to worry anymore....works great
2005 polaris predator 500 fan fuse
2005 polaris sportsman 500 fan fuse
fan not coming on in my polaris sportsman
fan on my polaris predator is not working
fan stopped working on my polaris 500 sportsman
polaris fan not coming
polaris predator 500 fan not working
polaris predator fuse on rad
polaris predator long road trips
polaris sportsman fan not turning on
polaris sportsman fan not working
predator 500 fan not coming on
Only one rear wheel turning!!!! HELP chillmouser ATV Repair and Maintenance 3 10-02-2011 08:47 AM
turning up springs/shocks on 2010 550 xp Ed H ATV New Members 5 01-03-2011 07:25 AM
turning starter post buckshot276 ATV Repair and Maintenance 1 10-27-2010 02:01 PM
sound in rear end when turning tight? jeepguy Polaris Sportsman 2 04-29-2010 03:14 PM
Odd Noise in Rear End While Turning pasty64 ATV Repair and Maintenance 2 09-24-2009 02:06 PM
