10-30-2011, 11:28 AM
Member #20051
2003 predator no spark
Just picked up an 03 predator 500 the guyn i got it from said it hadnt been ridden in atleast 4 years that he knows.Got it home drained the fuel put a new battery in it.It cranks over real strong but wont start,pulled plug and it has no spark .I ordered a manual for it but can i start checking in the mean time
10-30-2011, 04:22 PM
11-08-2011, 01:48 AM
Member #7709
i have a 2003 600 with no spark, how to i test the cdi unit 4010785? does anyone have a good cdi for sale?
11-08-2011, 01:49 AM
Member #7709
11-08-2011, 01:57 AM
Member #7709
how does the cdi work?
11-08-2011, 03:34 PM
Member #13071
you can only run a cdi off a predator 500 03-04. I would check to make sure you dont have a bad key switch or a kill switch grounding out and not giving you spark before going to the cdi. there is also a black sealed bag back by the rear shock that has a self resting breaker that when get dirty or wet over time go bad. You have to cut that bag open to check it tho.
11-08-2011, 04:58 PM
Member #7709
whats the best way to test a key switch and kill switch? does the breaker have a button for manual reset, or do I just bypass it , if it's bad to test to see if i have spark?
03 polaris predator weak spark, 03 polaris sportsman 600 twin no spark, 2003 polaris 50 no spark, 2003 polaris predator 500 no spark, 50cc polaris atv no spark, no spark predator 50, polaris 32388600, polaris 4010785, polaris 4060209, polaris 50 2003, polaris 50cc predator no spark, polaris atv predator 50 no spark, polaris preadator 50 lost spark, polaris predator 50 no spark, polaris predator 500 lost spark, polaris predator 500 no spark, polaris predator 500 no-spark, polaris predator 90 no spark, polaris predator one spark, predator 50 no spark
