Old 10-31-2011, 05:00 PM
luvriding's Avatar
Member #19943
Hi Just bought a Predator, got a few ?
Hi all Just bought a 2006 Predator, against what others said. I rode it and liked better than anything else I had ridden especially for the price.
I took it out the first time and had a problem with the 2005 450r carb the previous owner put on. The bolts that hold the arm link to the throttle valve came out and the clip on the jet needle had come off. I can only think the guy had this carb apart and did not reassemble it correctly. I am now going over everything to make sure nothing else is wrong.
I have read alot of the posts but wanted to be sure that the black cap on top, I think its called the valve set, should be plugged and I can cut the wires on the heater assembly. Last the main jet is a 190 and the slow jet is a 48. The bike seems to run rich while it ran. Does this sound correct? Should I go to a 180 main and 42 slow.
Any other suggestions let me know.
All my buddies said see we told you not to buy a Polaris and they are on Honda 400exs/300exs. I said the only thing wrong is the Honda part.
Old 10-31-2011, 05:10 PM
Old 10-31-2011, 07:20 PM
starpuss's Avatar
Member #16228
Think he installed a 450cc head on her?
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 10-31-2011, 07:49 PM
luvriding's Avatar
Member #19943
No its the Stock head. It has 4 bolts and the Honda only has three.
Old 11-01-2011, 03:45 PM
joshr08's Avatar
Member #13071
alot of guys run the TRX450r honda carb on the predator. go over to Polaris Pro Riders and introduce yourself then go down to the predator section and post the same question tons of guys there have ran the 450 carb on the predator. I had one then oped to stick with the stock cv carb.
Old 11-02-2011, 04:54 AM
luvriding's Avatar
Member #19943
Thanks for the info I will do that.
05 450r carb on predator
cost to get 2006 polaris predator jetted
looking for a 2005 polaris predator in stlouis mo
polaris predator 450r carb
polaris predator with trx450r carb
predator
trz 450 carb on 558
Just bought an 03 predator 500, advice? Jckpredator ATV New Members 3 05-08-2011 06:40 PM
New Member just bought a Polaris Predator Polaris Pred ATV New Members 12 05-08-2011 07:29 AM
Just bought 2006 polaris predator 500 tld Will not run Jaf711 ATV Repair and Maintenance 5 01-20-2011 01:12 PM
Bought an X2. Did I do well? Amccoy ATV Purchasing and Price 5 12-17-2010 01:52 PM
I just bought my 2006 Predator 500..gotta few ?'s twrhnd3 Polaris Predator 6 10-07-2010 03:16 PM
