Old 11-05-2011, 10:10 PM
snager's Avatar
Member #20203
predator will not start help please.
Just rebuilt low end of my 2005 predator 500 sport atv. Truns over but will not run??? Timing perfect, new plug, fresh fuel all lines are good and getting fuel, has good spark, did a compresion test at 120 books calls for 130, did a leak down test test good, clean carb was perfect. Do not under stand why it will not start ???? Please help before i roll this one of a cliff. When we go to start it will not even pop over even if we spray carb cleaner in carb as we are trying to start.
Old 11-05-2011, 10:35 PM
starpuss's Avatar
Member #16228
did you install the flywheel key?
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 11-06-2011, 05:06 AM
Old 11-06-2011, 05:27 AM
Gear_Head's Avatar
Member #14439
You say timing is good, have u checked for good spark?
Old 11-25-2011, 07:56 PM
QUICK04Predator's Avatar
Member #19945
Check the intake boot between the carb and engine, if its dry rotted or cracked it wont run. Just a thought.
Old 11-29-2011, 04:02 PM
JFoley001's Avatar
Member #18462
Sounds like spark to me, too
2005 Predator 500 TLD K&N Dyno Jet Pro Armor
2007 Predator 500 CUSTOM CREATION by REDNECK2725
03 polaris predator no start
2005 polaris predator 500 has fuel spark and wont starting
2005 polaris predator wont start
2005 predetor will not start
compression test for polaris preditor 660
is the 05 predator 500 a good atv
my 2005 predator 500 wont start
my polaris predator 500 turns over but wont start
my polaris predator 500 wont start unless i pop start it
my predator 500 stoped running wont start
polaris predator 500 carburetor clean
polaris predator 500 how to clean carb
polaris predator 500 will not crank
predator 500 metal in lower end
predator not getting fuel
predator wont start
why wont my 2005 polaris predator 500 start
predator no start pink63impala Polaris Predator 81 12-02-2011 02:23 AM
03 predator 500 no start mxracerx37 ATV Repair and Maintenance 2 03-21-2011 06:40 AM
Predator 90 will not start sauerkraut89 ATV Repair and Maintenance 2 03-20-2011 04:08 PM
Polaris Predator 500 (No Start) sidejob ATV Repair and Maintenance 6 01-19-2011 07:18 PM
Predator 500 Wont Start burton_predator500 ATV Repair and Maintenance 0 07-14-2010 08:00 AM
