Old 11-16-2011, 09:57 AM
neandrathal's Avatar
Member #18595
Sprockets
Im changing y front sprocket and my retaining ring doesnt fit my new sprocket is it okay too trim away the part needed too make it fit or does it have too be on there with holes lineing up properly?
Check out my preddy
Old 11-16-2011, 10:20 AM
starpuss's Avatar
Member #16228
Yup you must of got a Aftermarket Cheap LOW end one "race driven ??". so yes you will need to Trim off a bit. so you can line up the Bolts. also your chain may be 1-2 links too long (if you got the kit) , i have had a talk with them and they told me that i dont know what i am doing and the parts are a Direct replacement fit.... i have used 6-7 of there kits and 1/2 of them are NOT Direct replacement but they can be made to work. and at 1/4 the price of the dealer there still a REAL good deal.
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 11-16-2011, 12:27 PM
Member #18595
ya its funny cuz its a moose sprocket but i made it work now i need a different chain now or a different rear sprocket cuz im not lining up.......................grrrrrr
Check out my preddy
Old 11-16-2011, 11:10 PM
starpuss's Avatar
Member #16228
if you Front was bad. you should of changed them all. seeing i bet your chain is bad also.
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 11-18-2011, 09:20 AM
Member #18595
The front wasnt bad i went from a 14 to a 15 then back too a 14 but i did figure out how too roll the bearing carrier too tighten up the chain and all is well now thnx for the help
Check out my preddy
2005 polaris predator 500 chain size
94 polaris atv chain sprocket replacement
aftermarket chain and sprockets for polaris predator
chain and sprocket kit for 2005 predator 500
chain and sprocket kit for polaris predater
changing a sprocket on a polaris fourwheeler
do i need to change sprockets on modified polaris 400 sport
front sprocket retainer honda
how to adjust sprocket on polaris predator 500
how to change sprockets on polaris scrambler
polaris predator 500 chain and sprockets
polaris predator 500 sprockets
polaris predator aftermarket chain and sprocketss
polaris predator sprockets
predator 500 sprocket and chain
predator 500 sprocket set up
sprocket and chain kit for polaris predator 500
stock 2005 polaris predator sprocket
stock predator sprocket
youtube how to change a front sprocket on polairs 500
sprockets sprockets sprockets Minnesota ATV General Discussion 3 08-09-2011 10:01 PM
Predator Sprockets beastlypredator500 Polaris Predator 1 03-07-2011 08:49 PM
New chains and sprockets HawgFlies ATV Repair and Maintenance 2 10-18-2010 11:40 PM
different sprockets for 99 trailblazer???? ford_boy ATV Performance Modifications 5 10-14-2010 02:07 PM
sprockets and chain 07Scrambler Polaris Scrambler 1 06-21-2010 04:41 AM
