Old 11-18-2011, 08:41 AM
maesm81's Avatar
Member #20566
Will not turn over
2004 Preddy 500 will not turn over. It will not jump start with a jumper box, and I also tried jumping it with the battery I pulled out of my boat for the winter. It will not pull start in any gear, just locks up the wheels and skids to a stop. I can turn the engine over manually. When I hit the button it just clicks once and then makes a wierd electrical noise I can't really describe. I pulled the starter out, and the gears look fine. I hooked the solenoid up with the starter out and it spins fine, but when I put all back together nothing. In the service manual I see something about a one way starter clutch, but I know nothing about this. Maybe my problem? Any suggestions? Any help is greatly appreciated.
Old 11-18-2011, 09:16 AM
neandrathal's Avatar
Member #18595
you may need a new rectifier or cdi but try a brand new battery first mine had the same problem only made the buzzing noise got a new battery and it started first fire...........
Check out my preddy
Old 11-18-2011, 02:42 PM
Old 11-18-2011, 02:44 PM
buckwild kid's Avatar
Member #12643
Have you tried jumping accross the terminals on the starter relay by the battery? That will rule out the relay if the starter doesn't kick over.
2003 Polaris Predator 500, FMF Power Core 4 full exhaust, K&N drop in filter
2000 Polaris Sportsman 500
Old 11-18-2011, 03:25 PM
joshr08's Avatar
Member #13071
1 way gear
Old 11-18-2011, 10:40 PM
maesm81's Avatar
Member #20566
Bruce: Thank you!
Neandrathal: Even after trying with a jumper box and another known good battery, you think my battery could be the problem? If I take the battery out of my polaris and install it in our Honda 400ex it fires that quad right up. I will keep this in mind if I can't find any other solutions. I read in the service manual that it won't push or pull start with a bad battery, but it won't even turn over or try to start on a pull attempt. Maybe you're on to something. May have to buy a battery if nothing else seems to work.
Buckwild Kid: The starter does click and act like it wants to turn the engine, but just seems like something is holding it up.
Joshr08: 1 way gear? Do you think this is why my starter won't turn the engine over? Is this the same thing as the one way starter clutch? Or is it a different part?
I really appreciate all your suggestions. I will not be able to work on it until maybe Sunday morning. I will let you know if I figure it out then. Does anyone know what kind of voltage I should have at the starter solenoid when cranking? Or even what kind of voltage drop on the battery I should see? Once again, I appreciate all your help. Thank you!
Old 11-19-2011, 05:26 PM
joshr08's Avatar
Member #13071
yes its the starter clutch setup im guessing your bolts backed out of the one way gear and wont let it roll over pull your flywheel cover and the flywheel if its the one way your cases will be marred up and your flywheel will not turn
03 predator 500 starter and all gears turn but motor wont
08 polaris atv won't turn over even tried to pull start it
atv battery will not turn engine
atv doesnt turn on
atv engine makes noise wont turn over
atv starter wont turn over engine
atv that will not turnover
atv will not turn over
atv wont turn over
atv wont turn over and pull start not
cdi box on a 2003 predator 500
kids atv and battery will not turn starter
my polaris predator won't crank
polaris predator 500 wont turn over
polaris sportsman starter will not turn over
polaris starter locking up motor
polaris wont turn over
predator cdi box hums
quad wont turn over
why wont my atv crank
4x4 does not turn off by switch and tires wont turn but axle do Jzander27 ATV Repair and Maintenance 2 10-25-2011 10:04 PM
polaris 330 won't turn over tchad71 ATV Repair and Maintenance 2 05-11-2011 01:35 PM
Can i turn them? djtates125 ATV Wheels & Tires 11 03-24-2010 11:35 AM
02 scrambler 50 won't turn over mdutton ATV Repair and Maintenance 1 10-16-2009 04:54 PM
300 2x4 won't turn over Pakman ATV Repair and Maintenance 0 05-29-2009 08:55 AM
