Old 11-23-2011, 06:52 PM
Lowrider06's Avatar
Member #20728
seals
i need to replace the lip seal on my 03, problem im having is how do i get the sprocket hub off.....are they pressure seated or what thanks
Old 11-24-2011, 06:06 AM
Old 11-25-2011, 07:45 PM
QUICK04Predator's Avatar
Member #19945
There is a little clip on the outside of the sprocket hub you have to take off to pull the hub off. you will need to loosen the axle nut or take it off to get enough play in the axle to get the clip out. Look closely and you can see the clip on the sprocket side. The is a clip exactly like it on the side where the axle nut is.
kolpin
tranny seals jstanotherjoe ATV Repair and Maintenance 0 04-24-2011 08:30 AM
Front hub seals 2001sportsman400 ATV Repair and Maintenance 3 11-01-2010 06:36 AM
Crank Seals Ozquad ATV Repair and Maintenance 2 05-15-2010 07:19 PM
HELP Crank Seals wolfenstien ATV General Discussion 0 11-17-2009 04:29 PM
Seals leaking? jimfaststeel ATV Repair and Maintenance 1 09-09-2009 09:27 PM
