11-27-2011, 09:05 AM
Member #19261
Front shocks
hi i have a 05predator troy lee and was wondering how to adjust the front shocks
11-27-2011, 10:41 AM
Member #13071
easiest way to adjust them is lift the front end off the ground then turn the collars at the top of the springs up to soften the ride or turn them down to stiffen the ride
11-27-2011, 09:56 PM
11-28-2011, 11:22 AM
Member #19261
is the bbottom collar supposed to be attached to the spring? if i adjust it to high up the spring can slide up and down-
11-28-2011, 03:03 PM
Member #13071
that will happen until you put the quad back down on the ground. i wouldnt make it to soft or you will bottom out if you hit bumps
11-30-2011, 09:06 AM
Member #19261
alright thank you i just thought i broke my springs or something
04 predator tld front shocks, collars on front struts for polaris trail boss, how to adjust atv shocks, how to adjust fox shocks predator, how to adjust front atv shocks, how to adjust front shocks on predator 500?, how to adjust front springs on polaris atv, how to adjust shocks on atv, how to adjust shocks on atv to lower front end, how to soften the ride on a polaris outlaw, how to tighten the springs on a polaris atv, polaris atv front shocks, polaris predator front end, polaris predator front end], polaris predator front shock, polaris predator shocks, predator front shox, replacement front shocks for polaris predator 55, soften polaris predator front shock, why are the shocks on my predator 500 stiff
