Old 11-27-2011, 11:44 AM
Pred's Avatar
Member #18977
Pred sprocket and chain
I love my 07 Pred 500! I do not plan on porting or boring, or even rejetting. It is plenty fast enough , but I want to gear her lower. Please tell me the best Brand of chain and sprocket and also what sprocket[ # of teeth] to use in front and rear. Thanks!
Old 11-27-2011, 01:58 PM
joshr08's Avatar
Member #13071
to be honest with you i have ran every combination from 13/38 to 15/36 and everything in between not much of a difference in feel. little more top end on the 15/36 and a little more wheel spin on the 13/38 with a bit less top speed. Most chains are pretty equal these days as long as you keep them adjusted properly and lubed.
for a trail bike i wouldnt go lower then a 14 on the front or youll be eating your chain slider on the swingarm
Old 11-27-2011, 09:56 PM
Old 11-28-2011, 07:22 AM
03Grey500's Avatar
Member #14963
i'm running a jt sprocket up front with a 14 tooth and stock one in the back my buddy that also has a predator is running a 15 jt up front and one tooth lower in the rear (i don't remember how many teeth)
03 and 04 polaris swing arm lenghts
adjustment sprocket on polaris predator 500
best chain polaris predator
boaring predator 500
chain and sprockets on predators
how to change sprockets on a polaris predator
lowering the back of a polaris predator turning the swingarm
polaris predator 500 chain and sprocket upgrade
polaris predator 500 chain eating slider
polaris predator 500 eats chain sliders
polaris predator 500 sprockets
polaris predator 500 swing arm replacement
polaris predator 500 timing marks
polaris predator swingarm extenders
predator 500 15/36 gearing
predator 500 best chain
sprocket and chain size for polaris predator 500
sprocket for 03 predator
what is the best sprocket combination for predator 500
what is the best sprocket combination for the polaris predator 500
How often should I change the cam chain on my Pred Pred Polaris Predator 2 10-29-2011 05:33 AM
chain and sprocket neandrathal Polaris Predator 4 10-01-2011 08:28 PM
Recommended chain and sprocket brands? sinful ATV Repair and Maintenance 6 08-19-2011 09:58 AM
6x6 Chain and Sprocket replacement CosmoNont ATV Repair and Maintenance 3 05-31-2011 08:10 PM
Pred skips a beat like it jumped the sprocket? gmb357 Polaris Predator 0 03-22-2011 03:49 AM
