11-28-2011, 06:25 PM
Member #20895
2003 polaris predator 500
I have a 2003 Polaris Predator 500 with gas in the oil. Has anyone had this problem, and how can it be fixed? thanks
11-28-2011, 08:35 PM
11-29-2011, 03:52 PM
Member #18462
I have heard of fuel getting into the oil if the fuel cutoff petcock is not closed after riding. I would also think you would have to have a float problem in the carb for that to happen.
2005 Predator 500 TLD K&N Dyno Jet Pro Armor
2007 Predator 500 CUSTOM CREATION by REDNECK2725
11-29-2011, 04:18 PM
Member #20895
Alright I will check it out. Thanks
11-29-2011, 07:34 PM
Member #16228
if it was Runing and Driving , Drop the oil. Put in New Polaris Oil . Run her for 1-4 hrs and check your oil.
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
12-03-2011, 12:22 PM
Member #20895
I dont think that it was gas. I checked it after changing it and the oil level was really full. Im not familiar with the synthetic oil does it thin out after its gets warm or could something else cause the level of oil to increase
12-03-2011, 12:47 PM
Member #13071
if you have gas in the oil the oil will smell of gas. only other thing you could get in your oil is antifreeze. if thats the case your oil will look milky.
If you are getting gas in the oil your float height is to high or your needle is not seating properly and needs replaced.
12-03-2011, 01:00 PM
Member #20895
Whats wrong with it if the oil is milky
12-03-2011, 01:11 PM
Member #13071
most likely blown head gasket if its smoking or base gasket if its not smoking. water and antifreeze is getting in your oil if its milky.
if you have white smoke its water/antifreeze if its blueish its oil and if its black and smells like gas your rich
12-03-2011, 01:16 PM
Member #20895
Its not smoking and the oil smells like gas so would that be the base gasket?
2003 polaris predador motor oil type, 2003 polaris predator 500 carburetor, 2003 polaris predator 500 oil smells like gas, 2003 predator 500 oil, 500 predator has oil in carb, best oil for polaris predator, best oil for predator 500, changing oil filter 03 polaris predator, how much oil for 03 polaris predator, motor oil for polaris predator 500, oil replacement predator 500, polaris predator 500 float height, polaris predator 500 oil change, polaris raptor 500 frame, predator 500 cracked frame, what fuel is best for predator 500, what kind of antifreeze does 2003 polaris predator 500cc take?, what kind of oil for my polaris predator 2003, what type of oil does a polaris predator take, where do you add gear oil on a 2003 polaris predator?
