Old 11-30-2011, 04:34 PM
JoeW's Avatar
Member #18726
Choke question
On my garage sale special 03 pred 500. there is just a hunk of shredded cable sticking out of the choke housing. the plunger is there and the spring. What am I missing a knob or a lever or...?
Old 12-01-2011, 09:53 PM
rbvampire's Avatar
Member #20576
It's a Knob.
Old 12-10-2011, 06:25 PM
JoeW's Avatar
Member #18726
Ok it's a knob. Does it come right out of the carb or is there a cable and it mounts on the dash or somewhere else?
Old 12-11-2011, 03:35 AM
joshr08's Avatar
Member #13071
it comes out of the carb and runs under the gas tank and up to the dash. for like 5 bucks plus shipping you can get the carb mounted choke from jetsrus.com
Old 12-31-2011, 06:40 AM
JoeW's Avatar
Member #18726
Josh, do you happen to have a part number from Jetrus? I looked on their web site and couldn't find it so, I emailed them and got no response.
Old 12-31-2011, 01:31 PM
joshr08's Avatar
Member #13071
ill do better ill get you the exact page on there site for the part.
Old 12-31-2011, 01:34 PM
joshr08's Avatar
Member #13071
Jets R Us POLARIS PREDATOR 500 Just below the main jets is where you will find the choke.
Old 01-01-2012, 09:12 AM
JoeW's Avatar
Member #18726
Thanks Josh, Happy New Year!
changing choke cable on polaris 500 2005
choke assembly polaris outlaw 50
choke issui on polaris predator
choke spring on polaris outlaw 50
how does choke cable work on predator 500
how to get the choke cable off a polaris predator
how to remove carburetor on polaris outlaw 50
how to remove choke cable from polaris outlaw
how to replace choke cable on 2005 predator
how to take choke out of polaris predator 500
polaris choke assembly for outlaw 50
polaris outlaw 50 choak
polaris preator choke stuck
polaris predator 50 carburetor choke problems
polaris predator choke conversion
polaris predator choke problems
predator 500 choke cable removal
predator 500 choke spring
removing choke cable from polaris 300 hawkeye carb
replacing built in choke cable atv
04 choke cable humpbackshooter Polaris Sportsman 3 05-24-2012 08:04 PM
Choke issue? ssheehan Polaris Sportsman 1 08-23-2011 09:31 PM
'06 Hawkeye 300 Choke wilfor03 ATV Repair and Maintenance 1 01-06-2011 12:06 PM
Choke not working jriley43 ATV Repair and Maintenance 3 03-27-2010 12:36 AM
500 choke not working dieseldan2005 ATV Repair and Maintenance 0 11-29-2009 06:35 AM
