Old 12-02-2011, 09:24 AM
Ta2edphreak's Avatar
Member #13890
big bore kits
ive been toying with the idea of having a big bore kit installed on my 500, that being said would i get more or as much power out of upgrades like cams, ignitions, etc. what is the biggest bore you can achieve with the stock engine?
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
Old 12-02-2011, 05:18 PM
joshr08's Avatar
Member #13071
600 Hot seat kit = 1800
558 HPD Inc kit = 500ish
560 JE kit = 500ish but you have to buy everything and have the sleeve put in
636 Falicon Stroker kit = 2200 ish
558 is best bang for the buck send them your cylinder and get a kit back thats ready to bolt on.
cam 400 bucks for cams 400 for parts to go with cams
hot cams are junk
ignition 300 for a dyna fs programmable total waste of money if you dont pay to have it programmed for you and anything over 10,200 RPM's kills the valve train in the fuji motor.
pro com cdi are junk
any other questions please feel free to ask.
Old 12-02-2011, 07:06 PM
Member #13890
i looked at the 558 kit you mentioned, would i need to have valve work done to accommidate the bigger piston? or re-jet it? will stock carbs work...etc? and can i still use regular gas with it? what would the power increase be?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 12-03-2011, 04:12 AM
joshr08's Avatar
Member #13071
93 octane. 3-5 hp and stock carb works fine no valve work needed
Old 12-03-2011, 08:36 AM
Member #13890
will i have to have the machine re-jetted?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 12-03-2011, 12:41 PM
joshr08's Avatar
Member #13071
you should be fine with stock jets.
Old 12-03-2011, 09:04 PM
Member #13890
i think the only other concern i would have would be the transmission, will the stock tranny stay together with the extra power?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 12-03-2011, 09:16 PM
JFoley001's Avatar
Member #18462
Without plagiarizing I have read about a guy who blew (2) 04 trans 3rd gears w/ a big bore kit. He had a hard time until he swapped for an 05 tranny. Josh may have had different luck with his quad. He probably knows who I am talking about!
2005 Predator 500 TLD K&N Dyno Jet Pro Armor
2007 Predator 500 CUSTOM CREATION by REDNECK2725
Old 12-04-2011, 03:13 AM
joshr08's Avatar
Member #13071
actually 04 trannys are good its the 03's you have to watch out for. if you were going to have trouble with the tranny it would have already happened. do the big bore you will love it.
Old 12-08-2011, 08:04 PM
Member #13890
what are some good options for shocks? or would it be better to just have the stock ones re valved for my weight? and i never could figure out the rear shock adjustment knob {the fox blue knob}
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
03 predator 500 big bore kits
04 predator 500 bore kit
558 big bore kit
558 big bore kit predator 500
560 big bore kit for polaris predator 500
big bore kits for polaris outlaw 500
do 2003 polaris predertor 500 have transmission problems
how much can you bore a polaris predator 500
outlaw 500 big bore kit
polaris 500 big bore kit install
polaris atv big bore kit
polaris predator 500 big bore kit
polaris predator 500 big bore kit reviews
polaris predator 500 bigbore
polaris predator 500 engine big bore kit
predator 500 600 big bore kit
predator 500 stroker kit
what's the best big bore stroker kit for polaris outlaw 500
when do i have to sleeve a polaris predator 500
best big bore kit crashedpredator Polaris Predator 7 09-18-2011 06:16 PM
820 big bore kit flyin5.0 Polaris Sportsman 0 09-05-2011 04:46 AM
Big Bore Schwabbie93 Polaris Predator 1 02-12-2011 09:46 AM
Big Bore Kit Ryan Polaris Predator 4 12-14-2010 09:25 PM
big bore kits? Raimey ATV Performance Modifications 6 09-05-2010 05:49 PM
