Old 12-15-2011, 08:39 AM
Hillbillydrummer's Avatar
Member #20918
2005 Predator Will Not Shift
Hello. I recently installed a new timing chain in my pred, which went pretty smooth. I then had a problem with the clutch not working but that is now not an issue. However, now the pred wont shift gears. It will go in and out of neutral but thats it, where as before I could grab the shifter with my hand and go Reverse all the way up and back down. When I was troubleshooting the clutch, I took the shifter assembly behind the basket off and then removed the piece the shifter rides on to actually shift the gears. I got everything reinstalled but I may have gotten something out of line or something. Any help appreciated! I included a picture of my set up behind the clutch basket if it will help. Thanks!
05 predator 500 hard to shift down
07 polaris predator hard shifting
2005 polaris 700 cant shift
2005 polaris predator 500 problems
2005 polaris predator 500 shift s
atv wont shift out of first
hard clutch on 500 predator
having problems with my 2005 polaris prediter 500
polaris predator 500 gear problem, neutral only
polaris predator 500 hard downshifting?
polaris predator gear not catching
polaris predator shifter inop
polaris predator shifter popped out now it wont shift
polaris predator will not shift out of first
polaris quad wont shift into gear
predator 500 is hard to shift
predator 500 tightening gear shift
predator gear shift lever
predator500 not shifting
why my atv wont change gear
2005 Predator 500 CalCity ATVs For Sale 2 07-24-2011 07:26 AM
2005 Sportsman 700 - Hard to shift P_olaris ATV Repair and Maintenance 6 05-11-2011 10:34 AM
looking to buy a 2005 predator 500 raulibarra3 ATV General Discussion 2 02-22-2011 06:05 PM
2005 Sporstman 700 Shift Problem P_olaris ATV Repair and Maintenance 1 12-19-2010 12:11 PM
2005 Polaris 500 ATP Won't Shift into Gear Codiusprime ATV Repair and Maintenance 2 12-14-2010 04:44 PM
