Old 12-15-2011, 10:23 PM
Sweenman 88's Avatar
Member #15304
rear axle help!!!
first off i would like to thank whoever will be able to help me out... And please dont laugh at my inexperience with this situation.
I was prepping my bike today to go for a nice ride over the weekend... i changed the oil flushed the coolant changed a wheel bearing and changed a circut breaker.... i then started working on the rear end of the bike, due to a problem with my rear break ( the bracket that holds the calliper is loose and rattles) so i started taking my wheel off, as i was jacking the bike up i noticed that i could shift my axle easly (in any direction)...
i'm just wondering at how much it would run me to get it fixed at a shop... cus i really dont feel like doing it myself... thanks again to anyone that can answer me!!!
Old 12-19-2011, 07:56 PM
Ta2edphreak's Avatar
Member #13890
mine has the exact same problem at this moment, i think the axle shifting thing is rear axle bearings, the brake thing i have no idea, i just try to use the fronts, the rear brake lever dosent seem to do much on mine anyway unless i really push it far down. same as yours??
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
Old 12-19-2011, 10:21 PM
POLARIS13's Avatar
Member #20347
do you mean you could spin it forward and backward while in gear!? like it had a little play!? or side to side!?
Old 12-20-2011, 04:11 AM
racer37l's Avatar
Member #5629
If you're talking about the axle having slack at the diff, that is normal to an extent. Can't tell you why or how the slack happens, other than possibily from wear.
Con
Old 12-20-2011, 04:41 PM
Member #13890
no like if i put a cement block under the rear so that the tires are off the ground, and i grab the axle and push and pull back and forth the axle moves probably 1/4 to 1/2 an inch or so total, is that normal?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 12-21-2011, 09:55 AM
neandrathal's Avatar
Member #18595
NO ITS NOT YOU NEED NEW REAR BEARINGS, NOT HARD TOO REPLACE DID MINE VERY RECENTLY GET ON UTUBE AND LOOK UP ATV REPLACEMTN BEARINGS OR BETTER YET HERE IT IS, ITS JUST AN IDEA OF HOW YOU DO THEM NOT THE ACTUAL PREDATOR
OHH YA AN IF YOU HAD STEERING PROBLEMS THAT WILL FIX IT.........
Check out my preddy
Old 12-21-2011, 06:16 PM
Member #15304
thx guys!!! and yea for the questions about the brakes... the rear breaks dont do s**t loll
Old 12-21-2011, 06:20 PM
Member #18595
Did you bleed em an make sure u hve brake fluid?
Check out my preddy
Old 12-22-2011, 07:11 PM
Lowrider06's Avatar
Member #20728
i got the same problem brake and rear slack though i have a lot of rear slack so im gonna replace all bearings and seals....since i gotta take it apart might as well do it all and get it done with but im gonna wait till spring
Old 12-22-2011, 07:19 PM
Member #18595
Yeah soonerthe better dont wanna ruin your carrier for they are pricey
Check out my preddy
2003 polaris predator 500 axle bearings
2003 polaris predator 500 rear brake bracket has play
atv rear axle nut predator
axle removal polaris predator
how much shop time does it take to change the rear axle bearings on a 2003 polaris predator 500?
how take apart an axle for 03 polaris predator 500
how to change axle bearings in a polaris predator 500
how to put in back end bearings on peadator 500
how to take off rear wheel bearings of 03 polaris predator 500
polaris predator 500 can't get axle nut off
polaris predator 500 rear axle has play in it after changing bearing
polaris predator axle removal
polaris predator rear bearing removal
predator 500 loose axle
predator 500 rear axle not goin on
predator normal axle play
predator rear end disassembly
rear axle bearing for 2003 polaris predator 500
scrambler 500 axle nuts stuck
what side do the wheel seals for 03 polaris predator 500
Rear axle removal RubiconChris ATV Repair and Maintenance 5 07-26-2011 07:02 AM
How to Remove Rear Axle b_horner79 Polaris Sportsman 6 07-25-2011 09:26 AM
Moving rear axle Mclark ATV General Discussion 1 07-08-2011 05:26 AM
Rear Axle for 97 500 4x4 Rooster0310 Polaris Scrambler 2 07-04-2011 06:44 AM
Stuck Rear Axle hub nut HELP! shane_zuk ATV Repair and Maintenance 5 04-19-2011 04:49 PM
