Old 12-17-2011, 08:18 PM
33dauer's Avatar
Member #21382
motoworks sr4
found these on ebay and was wondering if anyone has used or delt with one, seems like a good deal but not if its junk. thanks 33dauer!!
Old 12-18-2011, 04:52 AM
joshr08's Avatar
Member #13071
HMF or pure polaris pipes make the best power in that order. PP are hard to find as they are no longer made. You can run a slip on as your not going to find a head pipe that flows better then the stock one unless you get a Rath header. Its the only one that was ever made that didnt lose power on a dyno run that i have ever heard of. Just make sure if you buy a slip on that is made to run on the stock header or you might run into trouble with pipe length.
Old 12-18-2011, 08:25 AM
roadiestar's Avatar
Member #13197
They make a excellent exhaust. There quality is excellent and so is there customer service. The Can-am factory racers use them.
Old 12-18-2011, 08:27 AM
joshr08's Avatar
Member #13071
But that doesnt mean its a good pipe for the predator motor.
Old 12-21-2011, 03:30 PM
33dauer's Avatar
Member #21382
well found 2 pure polaris slip on mufflers, made an offer on one and waiting to gear back!!
Old 12-24-2011, 10:02 AM
dragginby77's Avatar
Member #20803
im not sure if what i had was the pure muffler or not.. it was black with out baffles and had a deep throaty sound.. i took it all off and switch to a full yoshimura system and i like it a thousand times better combined with a 155 main jet it absolutely screams.
Old 12-24-2011, 12:47 PM
33dauer's Avatar
Member #21382
all the polaris ones i have seen are alluminum with supertrape type dics's for baffeling, the stock is black and mine has the rear off of it. got a nice one of ebay for 139!!
motoworks exhaust predator 500
motoworks jetting polaris predator
motoworks sr4 predator
motoworks sr4 predator 500
outlaw polaris motoworks
polaris 500 motoworks sr4
polaris predator motor works pipe
Motoworks SR4 slip on FOX92 Polaris Outlaw 1 07-22-2011 09:17 PM
