05 Predator Wont Fire! Help!
I recently replced my timing chain on my pred. I set everything to tdc using the T mark...I have seen posts saying to use the line to the left of the T mark...I'm not sure which is correct. Anyway, new chain, new plug, new oil and filter, and fresh gas. I hit the starter and it fired for a second and shut off and I cannot get it to fire again. My intake cam is setting with the dots at 9 and 12 with the 9 dot just below level with the head but still visible. The exhaust cam is the same but 1 tooth forward. Any ideas?
