Old 01-07-2012, 06:21 PM
mudkicker's Avatar
Member #15075
Question Sand Racing
ok, so my brother and i went to the local dunes today for the first time with the preds and they ran great but there is some mods to be done... we raced alot of bikes"all of which had paddles" and we didnt. to take off they would leave us but towards the end of the race we would start closing the gap. the problem was we needed paddles.. bad. so heres what we want to do, change sprockets and put paddles. we want to slow them down a bit on top end and give them more take off. what size sprockets should we go with and what type of paddles does good on these bikes?
Thanks!
_____________________
10 Sportsman 550EFI
05 Predator 500
Old 01-07-2012, 06:43 PM
outlawman 525s's Avatar
Member #5124
my first thought is ,i'd go with the sedona's 20x11x10's<that's what i run on my outlaw525s,i have all 3 front sprockets they make<13t,14t,15t>.i would take into consideration what mod's i have on the quad???than i would spend a weekend out running the new gear's"front or rear".what dune's are you in reference too?i'd test on straight drag lanes,hill climbing,and alot of time in the hole<shot> area.that's my personal thoughts on this.
thanxs David"wiquedone racing"Wilkie
A.K.A. Outlawman525s
P.S.glamis is the place 4 me
in the world of outlaws,we band 2gather and run as the fastest of the fast.Laughing at the yamahoppers,and the rest of them slow rides outherepilot license required,i meant firearms,two gun minimum!!!!!!!!!!!!!!!!!!!!and maybe a few grenadiersnot here
Old 01-07-2012, 08:42 PM
mudkicker's Avatar
Member #15075
Ok will def check them out!
My Predator has full HMF exhaust, jet kit and k&n air filter.
I ride at LA dunes. Mostly holeshot and drag, not much hill climb
Old 01-08-2012, 09:34 AM
Member #5124
holeshot'n and straight drag'n my best advise for ya is,sprockets are cheap,and good bang for the buck!but extending the swing arm<800+>,widen swing axle<300 on up>spindle extensions<65-75>add 2 inches wider on each side!and i'd really be looking your weight balance and center of gravity.and last would be rear shock settings are your biggest keys.best of lucky and hook-up and fly brother.oop's i'd also look into pro-com's hot box-add's about 1000 to 1200 more rpm's-shift point changes there.peace out. Dave
best sand paddles for polaris 500 outlaw
can you put sand paddles on a 2011 polaris 500 scrambler
how is a polaris predator 500 in the sand
outlaw polaris sprocket sand 15
paddles for polaris predator
polaris predator drag bike
polaris predator drag sprockets
polaris predator forums sand drag
polaris predator sand
sand tires for polaris sportsman
take the end off my 525 preditor exhaust
what size of sand tires do i need
what size sand tires do i need for 2011 polaris scrambler
Sand clutch kit/Sand tires? (2012 Sportsman 500) factionfx ATV Performance Modifications 6 05-11-2012 07:39 PM
Polaris Fluids and Belts....POUND SAND!!!! recurveman Polaris Sportsman 85 08-30-2011 03:08 PM
Sand Hollow State Park, UT. MandAtaco Western States 2 04-05-2011 07:31 PM
Sand Tires ScrammyTyler Polaris Scrambler 0 03-03-2011 03:28 PM
need case to protect camera from sand krazybob ATV Media 3 02-17-2011 05:55 AM
