Old 01-19-2012, 09:33 AM
jeepin88's Avatar
Member #22158
wheel options
hi, i just purchest a 2003 predator. so far i enjoy it when i get it to start. it needs tires, i am woundering what other rims will fit these quads. i see alot of rims and tires for sale but the tires rims size is diffrent. i am just looking for diffrent options.
thanks
jake
Old 01-19-2012, 08:13 PM
Old 01-20-2012, 04:16 PM
joshr08's Avatar
Member #13071
unless the stock hubs were swapped out your stuck with the 4/156 front and rear pattern. If swapping to a 04+ rear hub you can run a 4/110 pattern from newer predators, hondas and suzukis i believe.
And once again Bruce gret helpful info.
If you really would like to find out everything on the predator hop over too
Polaris Pro Riders Im co-owner there
tons of help
Old 01-23-2012, 10:10 AM
jeepin88's Avatar
Member #22158
do the 04+ rear hubs bolt on or is there mods that need to be done
jake
Old 01-23-2012, 02:24 PM
joshr08's Avatar
Member #13071
bolt right on
02 polaris preditor wheels
04 polaris predator bolt pattern
polaris 4/156 rear hub#gsc.tab
Options for XP lod666ftw Polaris XP 2 12-18-2011 10:34 AM
Handle bar options MightyThor ATV Performance Modifications 0 10-28-2011 01:07 PM
If only there were less options... Easytarget ATV New Members 4 03-31-2011 02:44 PM
Intake Options... jrhammo169 Polaris Predator 10 02-08-2011 06:03 PM
Oil options?? 43-north ATV Repair and Maintenance 17 10-08-2010 01:45 AM
