Old 01-26-2012, 04:59 PM
tysonstein's Avatar
Member #22685
Question 05 coolant leaking! anyone?
im about to buy an 05 predator and the guy says once its warmed up, it leaks coolant from the jug.... any suggestions of what might be wrong? easy or hard fix?
Old 01-26-2012, 07:01 PM
Old 01-26-2012, 07:11 PM
Where at on the jug?
Old 01-28-2012, 10:30 AM
tysonstein's Avatar
Member #22685
The bottom. Might be the hose maybe
Old 01-28-2012, 11:34 AM
joshr08's Avatar
Member #13071
base gasket most like needs replaced
01 sportsman 500 leaking coolant
atv leaking coolant
polaris atv radiator leak
polaris coolant leak
polaris leaking coolant
sportsman leaking coolant
97 xplorer 500 leaking coolant and overheating bgdb26k ATV Repair and Maintenance 7 12-08-2010 03:09 AM
Allied Electricals: Coolant Pump | Industrial coolant Pump in India Bangalore Allied Site Issues & Suggestions 1 11-19-2010 01:13 PM
1999 Sportsman 500 Coolant Leaking from web hole? rslscobra ATV Repair and Maintenance 1 08-03-2010 09:06 PM
04 Sportsman 700 Leaking Coolant Sekora ATV Repair and Maintenance 4 06-04-2010 06:02 PM
2000 sportsman 500 leaking coolant kaboomb ATV Repair and Maintenance 2 09-23-2009 03:14 PM
