02-02-2012, 02:14 PM
Member #13890
The voyager looks like a nice price of gear definitely, but I wanted the tach option because mine has a manuel gearbox, and the voyager is more money and more features than I need
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
02-02-2012, 02:16 PM
Member #22813
The Voyager computer kits will come with the wheel sensor as they are more accurate to use. You do not have to use it though if you do not want to. You can just set the computer to read speed and distance off of GPS. The reason that Trail Tech recommend using the wheel sensor is because they are more accurate for the speed and distance readings. Imaging you are out riding and you are logging with the computer and at the end of the day you load up in the truck and head home. You didn't remember to shut the computer off from logging so it records all of the trip home and adds all of that mileage onto the ODO. The reliability of the GPS is all based off of signal and sometimes the unit will switch to different satellites and just because of the rotation of the Earth when it receives signal it can say you have traveled a certain amount of distance when in fact you have not moved at all. The Voyager does also have a tach feature but if you do not need the GPS mapping feature then the Vapor computer would be the way to go.
02-02-2012, 08:09 PM
Member #13890
I guess I might have to do a write up on installing one then, if anyone is interested that is
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
02-04-2012, 01:34 PM
Member #13890
I forgot till ask another question, when I get the vapor I'll also be getting the big bar logo clamp, and a new set of bars most likely trail tech x bars, what bend do I go with on the bars with stock cables?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
has anyone installed vapor tach, how to install dynojet on polaris predator 500, how to install vapor computer kit on predator 500, install trail tech wheel sensor on polaris sportsman, intalling vapor predator 500, trail tech endurance 2, trail tech endurance atv, trail tech endurance ii, trail tech endurance ii review, trail tech endurance ii review \, trail tech endurance sensor mounting instructions, trail tech vapor polaris predator 500, trail tech voyager, trail tech voyager install wheel sensor polaris sportsman, trail tech voyager review for razor, trailtech endurance2, vapor tach for polaris, what hose do you use trail tech water sensor on polaris predator 500, whats the best polaris predator tachometer forum, where to install trail tech wheel sensor on polaris sportsman
