spark plug - Polaris ATV Forum
Old 03-23-2012, 09:30 AM
Ta2edphreak's Avatar
Member #13890
spark plug
This might be a dumb question but in going to ask it anyway, where is the spark plug located and how singling get to it on a 2003 500? And what are the best options for replacement plugs?
2003 Polaris Predator 500
Dynojet 155 Main Jet
K&N Square Air Filter
Maxxis RAZR Tires
Acerbis Handguards
Tusk Comp Series Heelguards
Tusk Comp Series Nerf Bars
Tusk Front Bumper
Armadillo 6 Pack Rack
Trail Tech Big Bar Logo Clamp
Old 03-23-2012, 06:38 PM
Member #13890
65 people looked at this thread and No one knows how to get the plug out?
Maxxis RAZR Tires
Acerbis Handguards
Tusk Front Bumper
Old 03-24-2012, 03:24 PM
ctrivelpiece's Avatar
Member #22823
Well time to answer your question, first turn your gas off, disconnect the fuel line from the tank. Next remove both black side covers (2 torax screws should fall right off). Next remove the front plastic, 2 torax bits (one on each side) and one bolt straight through the front vent then just slide it forward off the gas tank. If you go to take them off completely make sure you disconnect the headlights. Now remove the bolt out of the gas tank and slide the gas tank backwards and off. The spark plug is down in the head just pull the plug wire out and it should be 5/8 down in there. Its not as bad once you get it down pat. Takes me like 10mins. Just make sure if something doesnt give double check you got all the bolts/screws i might not have been exact and plastic is not cheap lol. Goodluck i check forums usually once or twice a day ill check back if you dont get it.
P.s I personally just stuck with NGK never had an issue yet.
03 polaris predator 500 spark plug gap
04 predator 500 best spark plug
2003 polaris predator 500 spark plug
2003 polaris predator 500 spark plug gap
best spark plug for polaris predator 500
how many spark plugs in a polaris predator 500
polaris predator 500 spark plug number
spark plug polaris predator 500
Spark plug Gap? M_Quick Polaris Sportsman 3 09-09-2011 02:50 PM
spark plug is dry awr90 ATV Repair and Maintenance 3 09-04-2011 08:49 PM
500 Spark Plug maverick11 ATV Repair and Maintenance 4 04-14-2011 06:36 AM
spark plug help! refg3880 ATV Repair and Maintenance 0 02-12-2011 07:52 PM
Spark plug SpartanTX117 Polaris Magnum 1 10-13-2010 07:19 AM
