02-21-2010, 05:06 PM
Member #3177
Predator shock question
Well, I'm a little confused about the shocks. My front has easy turn adjustable with no reservoirs. They appear to be just a generic red shock. The rear however is a Fox Podium X with the reservior. Are these considered stock? I read one thing that said the 07 Predators should have Fox shocks all the way around, and another that the TLE only had the Fox Shocks.
Any info on what I should have would be great. Also, are there stock fronts that have the reservoirs??
Thanks for any info to help understand this better
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
02-21-2010, 05:28 PM
yes, there are front shocks with the front reservoir... the 2006 predator had fox shocks with the reservoir, but in 2007 they came only on the LE models...both both the LE and non-LE 2007 predators had the fox shock in the rear, so yes, all sounds stock on your machine
02-21-2010, 05:35 PM
Member #3177
So I need to look for someone with a 06 that is upgrading, and buy their takeoffs
Thanks for the info
ITP Holeshot HDs
PRM radiator scoops
Engine Ice coolant
ODI Rogue Grips
02-21-2010, 05:41 PM
haha...yep. although i got that info from running an reverse search on the PN# in the dealer site....but when i went to the 06 microfiche, it still gave me two different front shock options based on predator model. one had the external reservoir, on did not, so you will still have to double check before buying. will depend on the model of predator
02-22-2010, 05:51 AM
Member #618
The 07 did not have reservoirs on the front.The TLD Preds had the reservoirs on the front and a short throw tranny.Non TLD's had pretty much the same setup as you have redneck.
06 Predator 500 TLD
07 Sportsman 500 EFI
09 Sportsman 550 XP
03-03-2010, 07:00 AM
Member #3428
All preds have fox susp, just a matter of what kind. Some had no rezzies, some had piggyback's in the front. All had the remote resivore on the rear shock.
You can add remote's to the non rezzie model shocks. Thats what the nipple lookin thing is on the top of the shock.
Here
Pure Polaris : Predator Compression-Adjustable Remote Reservoir)
04 Pred 500
Go fast stuff: Ceramic coated head pipe, HMF slip on, 450r carb, Rath intake, Uni filter w/outerware.
Look cool stuff: Rath bumper, Pro Armor nerfs. Black pc'd stem, a-arms, grab bar, bumper, nerfs and wheels.
03-03-2010, 02:15 PM
Member #3177
Here
Great info, thanks alot
ITP Holeshot HDs
PRM radiator scoops
Engine Ice coolant
ODI Rogue Grips
03-05-2010, 08:47 AM
Member #3181
Here
Not all Predators have fox suspension. In '07 they changed the front shocks to Arvin FX. All other years have fox with the TLD's having a piggyback shock.
Polaris Magnum 425
Yamaha Blaster 200
03-09-2010, 08:29 AM
Member #3548
07 is the one year you pretty much can't use as a comparison for anything. Polaris in their infinate wisdom decided to make a bunch of running changes on a line that was being discontinued.
03-12-2010, 09:02 AM
Member #3568
yea my 07 predator came brand new factory with adjustable fox podium x1 shocks with reservoirs on the front and back but it is a special edition
03 polaris predator 500 shock dimensions, add reservoir to fox podium shocks polaris predator, adding remote reservoir on fox podium, fox podium predator, fox podium shocks 2006 predator, fox podium shocks no reservor, fox shocks on a 2006 plaris predator, how do you adjust fox podium on 2006 polaris, how to adjust fox atv shocks, how to adjust fox podium shocks, how to adjust the rear shock on a 2006 predator 500, polaris 500 predator fox shock adjustment, polaris predatorfoxshocks, predator 500 front shocks, predator 500 rear shock bottom out, predator 500 shock dimensions, predator 500 shock length, predator 500 shocks, predator shocks settings, what is the stock shock length on a predator 500
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
rear shock
swifty scrambler |
Polaris Scrambler |
4 |
02-22-2010 01:36 PM |
predator 500 question
nathangillilan |
ATV Repair and Maintenance |
3 |
02-16-2010 02:38 PM |
Rear Shock Question
justincsandbar |
Polaris Scrambler |
2 |
01-10-2010 10:09 AM |
96 rear shock
djtates125 |
ATV Brakes & Suspension |
3 |
01-08-2010 08:10 AM |
shock wrench
n2mudn |
ATV New Members |
3 |
12-30-2009 06:53 PM |
