Old 03-08-2010, 09:57 AM
2whlfreak's Avatar
Member #1614
Bearing Sizes
I have to replace my wheel bearings and carrier bearings and I was wondering if anyone knows the sizes of the bearings and seals. So I can get them before taking everything apart.
Old 12-10-2010, 02:32 AM
bolt's Avatar
Member #9504
not sure what Quad you have.
My 2001 Polaris sportsman 500 HO 4x4 has a rear bearing size of 40x74x40
not sure on the front ones yet as I have not taken them off yet but will post sizes as I change the front bearings
Old 12-10-2010, 08:47 AM
SLIMSHADIE's Avatar
Member #6880
I just got my front hub bearings off ebay from Lytleracinggroup. They do have a website. Their ebay was still cheaper. Hope this helps.
Old 12-12-2010, 02:57 AM
bolt's Avatar
Member #9504
Hey SlimShadie what size are the bearings? and what year type of bike are they for?
Old 12-12-2010, 11:03 AM
SLIMSHADIE's Avatar
Member #6880
I already installed the bearings and cups. I know they were the AB25-1500 kit by Alls Balls, $11.80 each hub. I can't find the sizes any where, but it says its for 03-07 Predator.
Old 12-12-2010, 02:41 PM
bolt's Avatar
Member #9504
The best reason to know the sizes is so you can go to a generic bearing shop and pay less money for the same thing!
so if we made a list of bearings sizes for different quads we could use it as a reference for all of us
2001 Polaris Sportsman 4x4 500 HO [A01CH50AB]
Old 01-19-2011, 04:43 AM
nudy's Avatar
Member #11207
Alternative Polaris Sportsman Rear bearing list
thought this list might be useful. got it from this site: 510003 Auto Wheel Bearing 40x74x40:Sealed:Ball Bearings
510003 auto Wheel double row Bearing, here are the dimensions of the 510003, the 510003 inner diameter is 40mm, the 510003 outer diameter is 74mm, 510003 width is 40mm.
•Item: 510003 Double Sealed Ball Bearings
•Dimensions: 40*74*40 mm/Metric
•ID (inner diameter)/Bore=40mm
•OD (outer diameter D1)=74mm
•Width/Height/thickness=40mm
•510003 Closures: Double Sealed with rubber seals
•510003 Type: Wheel Ball Bearings
•Size: 40mm x 74mm x 40mm
•Quantity: One Bearing 510003
Fits the following Vehicles
•2006-2000 AUDI TT
•2006-2000 AUDI TT QUATTRO
•2001-1994 KIA SEPHIA
•2004-2001 KIA SPECTRA
•1995-1990 MAZDA 323
•2005-1990 MAZDA MAATA
•1996-1992 MAZDA MX-3
•2003-1990 VOLKSWAGEN PROTÉGÉ
•2008-1998 VOLKSWAGEN BEETLE
•2006-1995 VOLKSWAGEN GOLF
•2009-2006 VOLKSWAGEN GTI
•2005-1999 VOLKSWAGEN JETTA
•2009-2006 VOLKSWAGEN RABBIT
2001 500 polaris sportsman rear wheel bearings
2003 polaris front axle seals numbers
2003 polaris predator 500 rear wheel seals
2004 polaris predator 500 rim size
40x74x40 bearing
40x74x40 bearings
40x74x40 mm bearing
99 polaris sportsman 500 rear hub bearing numbers
different size bearings in sportsman front hub?
polaris predator carrier bearing size
polaris predator carrier bearings
polaris predator hub bearing
polaris predator rear bearing carrier dimensions
rear hub bearing sportsman 500ho 2005
size of wheel bearing on 2005 predator
two front bearings each hub 2005 polaris trailblazer 250
wheel and axel bearings same size on atv
wheel bearing 40x74x40
wheel bearing for polaris 500 1999
Front wheel bearing 1dodger99 ATV Repair and Maintenance 10 05-11-2011 06:43 PM
tire sizes for 00 500 rezrider ATV Wheels & Tires 0 02-27-2010 06:05 PM
Bearing seized to Crank? 04 Trail blazer 250 zk6216 ATV Repair and Maintenance 1 10-24-2009 07:56 AM
Rear bearing removal bulldog101504 Polaris Sportsman 4 09-02-2009 07:13 PM
Rear universal bearing rust Polaris Sportsman 1 08-13-2009 04:33 AM
