10-21-2010, 09:01 PM
Member #6880
I wish I knew about this screw 4 years ago, oh well. I added a prestone flush tee kit to mine.
This works good also.
03-12-2011, 04:21 PM
Member #12840
Hey Redneck,
Nice write up. I am gonna be changing over to the Engine Ice in a week or two and will definitely use your write up.
03-17-2011, 02:16 PM
Member #3440
i put the engine ice in my 850,,, wish i didnt go through all the trouble and spent all the money,, it didnt do a thing,, maybe it works on motorcycles, but definately NOT my xp
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
03-18-2011, 05:40 AM
Member #12554
This looks like an awesome write up! I'm going to tackle this job this afternoon and hope mine goes as smoothly!
05-05-2011, 10:23 AM
Member #3442
Just changed my this past week and what a difference, my fan doesnt come on nearly as much. Wish i did this a lot earlier!!!
05-05-2011, 02:10 PM
Member #3440
i guess in some machines it works better, like the sport quads and motorcycles
RIDE ON !!
09-23-2011, 11:08 AM
Member #18848
i need help with hookin my fan to a switch
12-15-2011, 10:17 PM
Member #15304
nice write up man i have an 06 pred and was wondering how to flush the coolant system! will definately use this sticky!!!
01-23-2012, 03:57 PM
Member #3702
I just changed my coolant again for the winter months. I work at a Honda car dealer and the oem coolant used is also blue like engine ice. I decided to try it out in my Pred. What a total difference its made. If anyone is interested, oem Honda coolant is most likely the same stuff and works great, my quads fan almost never comes on and it runs so much cooler.
2005 Predator
Stage 1 Hot Cams CFM oil tank UM nerf bars and heel guards
Pro Aluminum skid plate and front bumper
Pure Polaris pipe K&N filter Jet Kit
Renthal bars, chain and sprockets Battery relocated
Civic style intake
1997 Trailboss
Jet Kit DG pipe
Modded cylinder fitted w/ 400 V-Force reed valve
Milled cylinder head
Namura piston and rings .040 over
Moose Racing gaskets
02-19-2012, 03:40 PM
Member #22660
that was a nice write up. I'm new to owning my Predator and found this very helpful, thanks!!!!!!!!!!!!!!!!!!!!!!!
antifreeze polaris predator 500, changing coolant in a predator, coolant flush on a preditor 500, coolant for polaris predator, coolant for polaris predator 500, how to change antifreeze on a polaris, how to drain antifreeze polaris, polaris coolant change, polaris predator 500 coolant, polaris predator 500 cooling system, polaris predator 500 using antifreeze, polaris predator radiator fluid, polaris predator radiator flush, polaris sportsman 500, coolant change, predator 500 coolant, predator coolent, wahtskind of coolant to used on 03 predator 500, what kind of coolant dose a 2005 polaris predator 500 take, what kind of engine coolant do i put my polaris predator, what type of coolant does a polaris predator us
