04 Predator 50 carburetor settings - Polaris ATV Forum
Old 07-06-2013, 11:35 PM
EoinG's Avatar
Member #19126
Hello
The atv has been sitting for a while becaise it wont start so I took the varb apart and cleaned it and now I need the idle screw and AF settings.
Old 07-07-2013, 01:08 PM
RVS Performance's Avatar
Member #29606
Never should have pulled the idle screw out as they rarely need to be adjusted and there is no set number of turns for them. just have to turn it in and hope it's close and adjust from there. Mixture screw should be about 1.5 turns out and adjust for best throttle response from there.
Old 07-07-2013, 02:08 PM
tekrsq's Avatar
Member #6432
My manual says to start the AF screw at 3/4 turn out from slightly snug. It doesn't have a starting point for the idle screw, but mine is about 1 1/2 turns out.
08 Sportsman 800 Touring- EPI clutch turning 27" Mega Mayhems, 2500lb Polaris winch, front & rear SATV brush guards, front rack extender, 3 headlight Mod, Quadovator temp gauge, RAC Engineering reverse/ work lights, EBC brakes, Triangle ATV Stealth Snorkels, RDC radiator relocation kit, ATVtrailtunes split tube system, 12" Totron LED lightbar
08 RZR 800- SATV +6 offset long travel kit, Rhino axles, Walker Evans shocks, QSC clutch turning 27" Mud-Lite XTRs, 3500lb Polaris winch, 09 RZR-S exhaust, EMP 1/2 windshield, Air box relocation w/ custom snorkels, EBC brakes, BoeschBuilt parking brake, ATVTrailtunes speaker set, dual LightItUpOffroad LED whips, 30" Totron LED lightbar, 2x3 OPT7 cubes
05 Scrambler 500- Polaris rear rack, Bear Claw tires, EBC brakes (the wife's bike)
Grandkids- 04 Predator 50 (70cc big bore kit), 93 Yamaha PW50, 03 Yamaha PW50
Old 07-11-2013, 04:40 AM
EoinG's Avatar
Member #19126
Thanks I will give it a shot.
Old 08-02-2013, 03:39 PM
EoinG's Avatar
Member #19126
I pulled the carb out and cleaned it again and this time I flushed the tank and it starts no problem.
2005 polaris predator 50 carb settings
adjusting polaris 50 carburetor
factory carburetor settings on polaris outlaw 50
how to adjust carb on a predator 50
polaris 50 carb settings
polaris outlaw 50 carburetor adjustment
polaris predator 50 carb adjustment
polaris predator 50 carburetor
polaris predator 50 carburetor adjustment
polaris predator 50 idle adjustment
2006 Predator 50 Carburetor Vanbey Polaris Predator 1 06-02-2013 09:17 PM
Carburetor Settings GatorHunter ATV Repair and Maintenance 5 01-16-2013 10:38 AM
XP Spring Settings JimmyC Polaris XP 9 05-05-2012 09:08 AM
carb settings fred398 ATV Repair and Maintenance 2 09-07-2010 06:17 PM
Carb settings kbhd6180 ATV Performance Modifications 16 04-09-2010 07:08 PM
