How do i lower my predator - Polaris ATV Forum
Old 08-04-2010, 04:00 PM
PredKiller's Avatar
Member #6324
Hey guys, im new to this stuff and am wondering how i can lower my 05 predator 500? I have found the brackets and everything to lower the front up to 4" but nothing for the back. Any help would be great.
Old 08-04-2010, 07:26 PM
redneck2725's Avatar
Member #3177
The easiest way is 18" tires, for the most part however they do not sell "lowering" kits for the rear. Why do you want to lower it so much??
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
Old 08-04-2010, 11:53 PM
PredKiller's Avatar
Member #6324
I actually dont want to lower it that much but the only thing i can find for the front is the 4" kit. I would like to just lower it about 2" or so... I have no clue where to order parts or anything.
Old 08-05-2010, 03:39 AM
Member #3177
What kind riding are you going to do, and why are you wanting to lower it? The only, and I mean only reason to lower the Predator is if you are flat track or drag racing. If you actually take it out on the trails, it will make it nearly impossibly to ride any rough areas. I actually had to get taller tires to lift me up some, i constantly get my rear skidplate digging into the ground.
ITP Holeshot HDs
PRM radiator scoops
Engine Ice coolant
ODI Rogue Grips
Old 08-05-2010, 12:44 PM
PredKiller's Avatar
Member #6324
I dont plan on doing any flat track riding.... I understand what you mean... I will probably just leave it the way it cause all my friends ride dirt bikes so i will be taking it to the track with them... Ok, so if i wanna be able to take it off any big jumps do i need to upgrade anything on there before i do? It has the Fox Racing suspension.
Old 01-01-2012, 12:03 PM
beheler1's Avatar
Member #20931
How can I lower the read of my 1998 Polaris 500 4x4. I want to lower the rear about 2".
Old 01-02-2012, 08:56 AM
mudkicker's Avatar
Member #15075
i wanted to lower my predator as well but after reading this i think ill just leave it the way it is
_____________________________
10 Sportsman 550EFI
05 predator 500
Old 04-29-2012, 04:25 AM
predator500TLD's Avatar
Member #25784
how did you do to lower the rear of the pred? Im looking for kits both rear and front but only find front. Im riding flat
Old 05-09-2012, 04:06 PM
PolarisNutz's Avatar
Member #24202
my friend has a race ready pred it sits at 7 1/4 in the front and 7" in the back he has fire ball +2 a-arm razr mx's on all 4 corners podium xs re sprung in the front and a reworks back shock and those measer ments are with him of it
Old 05-09-2012, 05:13 PM
03Pred500's Avatar
Member #25509
Probably not the right way to do it but I just adjust the "pre-load". When I bought mine used, it sat like a flat tracker. I took off the nerf bars and cranked the preload into the front and rear shocks raising it up quite a bit. I wouldn't lower it too much as mine was too low. If I picked up the front end by my bumper the springs would actually flop a tiny bit in their mounts. That's why I cranked mine up now. It rides better too I think...
how to lower a polaris predator
how to lower a predator 500
how to lower polaris predator
how to lower polaris predator 500
how to lower predator 500
polaris predator 500 lowering kit
polaris predator 500 rear lowering kit
polaris predator lowering kit
polaris predator rear lowering kit
Any LA (Lower Alabama) Riders out there? istalvey Southeast 27 07-22-2011 02:15 PM
Injuried my lower back redneck2725 Around The Garage 14 08-02-2010 07:01 PM
lower cv boot chugnbug ATV Repair and Maintenance 5 05-09-2010 07:31 AM
Lower Navigation dascrow Site Issues & Suggestions 4 02-17-2010 08:10 PM
Check lower A-arm bushings popo ATV New Members 35 06-19-2009 12:31 PM
