Wont Start - Polaris ATV Forum
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Scrambler XP
Polaris Scrambler XP Discussions for the all new 2013 Polaris Scrambler XP 850
Old 04-07-2013, 03:18 PM
VNitri22's Avatar
Member #35376
Wont Start
I was riding my new Scrambler 850 xp it was running fine all day and then all of a sudden it just died. It will turn over and the exhaust will back fire every now and again. Does anyone have any ideas?
Old 04-07-2013, 05:42 PM
KICKER431's Avatar
Member #18006
spark plug boot fall off?
fuel valve get shut off?(not even sure if it has one)
Air filter get blocked?
If it is turning but not catching then it either isn't getting spark, air or fuel.
Sorry I can't be more help than that but we don't have much details to work with.
completely stock FOR NOW
26" Maxxis Bighorn 2.0
Old 04-07-2013, 07:33 PM
Old 04-08-2013, 06:09 AM
VNitri22's Avatar
Member #35376
Well thats what i was thinking it wasnt getting air, spark or fuel but i checked the air filter it wasnt clogged. I made sure the spark plug boots were still on good. Im just confused as to why it just stopped running.
Old 04-08-2013, 08:26 AM
bgirard420's Avatar
Member #11494
Wont Start
Throttle freeplay adjustment error? Probably the most common cause of new quad DOA.
Rather be riding, instead I'm using Tapatalk
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
Old 04-08-2013, 08:28 AM
gdwrd26's Avatar
Member #34316
Given the occasional back fire I'd guess its a bad sensor. I dont have extensive knowledge of the machines system but given its efi there's surely some position sensors involved that can go bad and cause that kind of issue. My best recommendation would be to take it in and let the dealer hook it up to the computer. They should be able to figure it right away. Other than that if you've made any modifications at all check to be sure no wires got pinched melted or otherwise grounded out. If youve done no mods then just go over the wiring harness in general in case nothing like the above mentioned happened.
Old 04-08-2013, 09:12 AM
Craig's Avatar
Member #3065
We all assume that the Red on/off switch on left handlebar is in the ON position, so as stated earlier check to see if the engine will start with the throttle barely depressed, if it does then it's just a simple throttle cable adjustment which is about 4 inches from the throttle housing on the handle bar.
2013 Sportsman 550 LE EPS Stealth Black
Atv-Guru bumpers
Heated thumb and hand warmers
Lock and ride front and back boxes
Garmin GPS
Polaris Billet shift Knob
All Balls Ball Joints
P3ATV.com Bushings
Grim Reaper Tires
"Polaris STEALTH" bar
Old 04-09-2013, 07:50 PM
VNitri22's Avatar
Member #35376
Thank you all for your input it will be going into the shop thursday and i will let you guys know what the verdict is.
Old 04-22-2013, 09:55 AM
Jonesey80's Avatar
Member #35750
Any word yet?
Mine did the same thing this weekend
Old 04-22-2013, 10:03 AM
VNitri22's Avatar
Member #35376
mines still at the shop and I have not heard from them in over a week.
2013 scrambler 850 want crank
my polaris scrambler 850 wont start
my polaris sportsman 500 motor mad a hige clanging and wont start
polaris 2015 850 wont start
polaris 850 2015 wont turn over
polaris 850 scrambler wont start
polaris p 2000i wont start
polaris scrambler xp wont turn over?
polaris voyager wont start
polaris wont start
scrambler 850 died
where is spark plug on my 2013 850 scrambler
2002 sportsman 400 wont start new stator. have spark wont fire roadjoker22 ATV Repair and Maintenance 13 11-03-2013 06:26 AM
Pull start/electric start wont catch wes910 Polaris Trail Blazer 2 01-21-2013 06:46 PM
2006 outlaw wont start when cold but will start when warm. heavyritefoot Polaris Outlaw 6 05-09-2011 02:42 PM
Wont start from a cold start. gramslam05 ATV Repair and Maintenance 5 11-28-2010 06:57 PM
94 300 4x4 Wont Start? Juggernaut_7 ATV Repair and Maintenance 4 08-02-2010 03:50 AM
